Старый 03.08.2006, 20:09   #1
svcoder is offline
svcoder
29 / 25 (1) +++
Различия между 3.0 и 4.0
Где в наиболее полном объеме можно почитать о различиях между 3.0 и 4.0?
Старый 04.08.2006, 14:09   #3
Recoilme is offline
Recoilme
злыдень
Аватар для Recoilme
895 / 192 (8) ++++++
Thumbs up Microsoft жжёт
Нет, я просто тащусь от этой компании ))
По приведенной мази ссылке, цитирую:
Direct SQL
When direct SQL is used through the Connection and Statement classes, it is subject to SQL injection threats. Classes that wrap these kernel classes—for example, the SysSQLBuilder classes—are equally dangerous. You should keep in mind that record-level security and field-level security are not enforced on the Statement class.
To learn more about SQL injection attacks, see the article, Stop SQL Injection Attacks Before They Stop You, on MSDN.
Ля-ля-ля - не юзайте прямой SQL пока он не поюзал Вас.
Открываем Читвёртую Аксапту, и что мы там видим? Правильно! Прямой SQL)))
/* This method will build following statement in a str:
execute sp_executesql N'UPDATE InventSum
    SET InventSum.CostAmountPhysical     = InventSum.CostAmountPhysical            +
                                           InventSumDelta.SUM_CostAmountPhysical,
        InventSum.PostedValue            = InventSum.PostedValue                   +
                                           InventSumDelta.SUM_PostedValue,
        InventSum.Qty                    = InventSum.Qty                           +
                                           InventSumDelta.SUM_Qty,
        InventSum.LastUpdDatePhysical    = CASE WHEN InventSum.LastUpdDatePhysical > InventSumDelta.MAX_LastUpdDatePhysical
                                                THEN InventSum.LastUpdDatePhysical
                                                ELSE InventSumDelta.MAX_LastUpdDatePhysical
                                           END,
        InventSum.LastUpdDateExpected    = CASE WHEN InventSum.LastUpdDateExpected > InventSumDelta.MAX_LastUpdDateExpected
                                                THEN InventSum.LastUpdDateExpected
                                                ELSE InventSumDelta.MAX_LastUpdDateExpected
                                           END,
        InventSum.ClosedQty              = CASE WHEN ((InventSum.PostedQty + InventSumDelta.SUM_PostedQty) = 0 AND
                                                      (InventSum.Deducted  + InventSumDelta.SUM_Deducted)  = 0 AND
                                                      (InventSum.Picked    + InventSumDelta.SUM_Picked)    = 0 AND
                                                THEN 1
                                                ELSE 0
                                           END,
        InventSum.Closed                 = CASE WHEN ((InventSum.PostedValue    + InventSumDelta.SUM_PostedValue)  = 0 AND
                                                     (InventSum.PhysicalValue  + InventSumDelta.SUM_PhysicalValue) = 0 AND
                                                THEN 1
                                                ELSE 0
                                           END
    FROM (SELECT SUM(CostAmountPhysical)    AS SUM_CostAmountPhysical,
                 SUM(PostedValue)           AS SUM_PostedValue,
                 SUM(Qty)                   AS SUM_Qty,
                 .....                      AS ...,
                 .....                      AS ...,
                 MAX(LastUpdDatePhysical)   AS MAX_LastUpdDatePhysical,
                 MAX(LastUpdDateExpected)   AS MAX_LastUpdDateExpected,
                 InventSumDelta.ItemId,
                 InventSumDelta.InventDimId
          FROM InventSumDelta
          WHERE InventSumDelta.DataAreaId   = @p1
          AND   InventSumDelta.TTSId        = @p2
          AND   InventSumDelta.IsAggregated = 0
          GROUP BY InventSumDelta.ItemId, InventSumDelta.InventDimId
         ) AS InventSumDelta
    WHERE InventSum.DataAreaId        = @p1
    AND   InventSum.ItemId            = InventSumDelta.ItemId
    AND   InventSum.InventDimId       = InventSumDelta.InventDimId
',N'@p1 NVARCHAR(3), @p2 BIGINT',@p1=%1, @p2='%2'
Прошу завести пользователя Майкрософт, я ему рейтинг понижать/повышать буду))
Ибо зло есть лучшая сила человека. "Человек должен становиться все лучше и злее" -- так учу я. /Ф. Ницше/
Старый 04.08.2006, 15:07   #4
EVGL is offline
EVGL
4,445 / 3001 (0) ++++++++++
Да ладно вам! Радоваться надо: люди работают, ускоряют медленные запросы.
Старый 04.08.2006, 15:10   #5
Recoilme is offline
Recoilme
злыдень
Аватар для Recoilme
Да пусть работают, я разве против?? ))
Старый 04.08.2006, 16:02   #6
Jabberwocky is offline
Jabberwocky
Microsoft Dynamics
Аватар для Jabberwocky
274 / 307 (11) ++++++
Сообщение от Recoilme
То, что Вы процитировали, это в Microsoft для Вас написали, а не для себя.
Старый 07.08.2006, 13:50   #7
Maxim Gorbunov is offline
Maxim Gorbunov
2,483 / 645 (26) +++++++
Ну и где там это написано? Что-то уж больно художественный перевод у Вас получился
Старый 07.08.2006, 16:50   #8
klo is offline
klo
А есть у кого-нибудь документация по Ax 4.0?
Старый 08.08.2006, 02:08   #9
Recoilme is offline
Recoilme
злыдень
Аватар для Recoilme
Сообщение от Maxim Gorbunov
Интервью с майкрософт в переводе Гоблина ч.2 ))
Честно говоря, настораживает почему то.. Может читсо теоретически пояснит кто, как это работает (ИМТС в 4) ??? ??? ???
Старый 08.08.2006, 09:52   #10
Maxim Gorbunov
"Программисты должны быть смелыми, чтобы не пугаться, когда все перепуталось так, что никто не разберет..." (c) Тарас
Старый 08.08.2006, 10:42   #11
Vadim Korepin is offline
Vadim Korepin
Dynamics 365 MR
Columbus IT
600 / 692 (25) +++++++
Сообщение от klo
есть конечно
для партнеров доступны описания нового в АХ в функциональности и технологиях, 600 и 200 страниц соответственно. Все есть на PartnerSource
Старый 08.08.2006, 11:16   #12
slava09 is offline
slava09
Аватар для slava09
Дети Юза
1,642 / 237 (11) ++++++
дайте плиз ссылку на PartnerSource, где все это лежит, если не сложно.
доступ есть.
Старый 08.08.2006, 12:02   #14
slava09 is offline
slava09
Аватар для slava09
Дети Юза
Спасибо.
Старый 08.08.2006, 12:56   #15
fomenka is offline
fomenka
А когда будет доступна информация для простых людей-не партнеров?
Или может уже что-то есть в свободном доступе?
Старый 08.08.2006, 13:05   #16
Сообщение от fomenka
http://forum.mazzy.ru/index.php?s=&s...ndpost&p=23124
Axapta 4.0. Когда?
См. также
http://forum.mazzy.ru/index.php?s=&s...ndpost&p=23177
Старый 08.08.2006, 15:07   #17
fomenka is offline
fomenka
Спасибо за ссылки, mazzy. Но все это прочитано уже. Вот если бы были опубликованы те самые 600+200 страниц, вот это было бы интересно! Неизвестно ничего о планах MBS в этой области? Не для партнеров, а для простых легальных пользователей Axapta?
Последний раз редактировалось fomenka; 08.08.2006 в 15:10.
Старый 08.08.2006, 15:16   #18
Vadim Korepin
Dynamics 365 MR
Columbus IT
fomenka, после перевода данных документов на русский язык, они будут опубликованы на клиентском портале.
Старый 08.08.2006, 15:18   #19
Вы же читали - этой осенью-зимой.
"Для простых легальных пользователей" в России Аксапта еще не появилась.
То, что сейчас обсуждается - американский релиз.
Старый 08.08.2006, 15:59   #20
Vadim Korepin
Dynamics 365 MR
Columbus IT
Для клиентов подобные треннинги выложены на CustomerSource по ссылке: https://mbs.microsoft.com/customerso...ewAX40Training
что нового, ax3.0, ax4.0
Как сделать AND между двумя датасорсами на одном уровне в query rkorchagin DAX: Программирование 15 15.01.2009 17:42
Разница между запросами Rect DAX: Программирование 13 05.12.2006 12:44
Расчеты между компаниями Yuri Nikitenko DAX: Функционал 9 15.11.2004 08:49
различие между Axapta и Attain andreynikolai DAX: Программирование 4 04.02.2004 17:53
дизайн отчета (как сделать его с разделителями между столбцами?) puz DAX: Программирование 7 02.09.2003 08:50
Часовой пояс GMT +3, время: 20:41.
