Старый 17.10.2006, 10:17   #21
Roman777 is offline
Roman777
Аватар для Roman777
320 / 64 (3) ++++
Что-то типа этого:
void initQuery()
query   query = new query();
QueryBuildDataSource  queryDataSource1,queryDataSource2,queryDataSource3;
QueryBuildRange  QRange1QRange2QRange3QRange4QRange5;
int postedQtyreceiveddeductedregisteredpicked;
queryDataSource1 query.addDataSourcetablenuminventTable ));
queryDataSource2 queryDataSource1.addDataSourcetablenuminventSum ));
queryDataSource3 queryDataSource2.addDataSourcetablenuminventDim ));
queryDataSource2.addLink(fieldNum(InventTableItemId), fieldNum(InventSumItemId));
queryDataSource3.addLink(fieldNum(InventSumInventDimId), fieldNum(inventDimInventDimId));
queryDataSource1.addSortFieldfieldnuminventTableItemId ));
queryDataSource1.addSortFieldfieldnuminventTableItemName ));
queryDataSource1.addSortFieldfieldnuminventTableItemGroupId ));
queryDataSource2.addSortFieldfieldnuminventSumInventDimId ));
queryDataSource1.orderMode(OrderMode::GroupBy);
QRange1 queryDataSource2.addRange(fieldnuminventSumItemId ));
QRange2 queryDataSource1.addRange(fieldnuminventTableItemGroupId ));
QRange3 queryDataSource1.addRange(fieldnuminventTableGroupTopId ));
QRange4 queryDataSource1.addRange(fieldnuminventTableGroupLevelId ));
QRange5 queryDataSource3.addRange(fieldnuminventDimInventLocationId ));
queryDataSource1.addSelectionField(fieldnuminventTableItemId ));
queryDataSource1.addSelectionField(fieldnuminventTableItemName ));
queryDataSource1.addSelectionField(fieldnuminventTableItemGroupId ));
queryDataSource1.addSelectionField(fieldnuminventTableGroupTopId ));
queryDataSource1.addSelectionField(fieldnuminventTableGroupLevelId ));
queryDataSource2.addSelectionField(fieldnuminventSumInventDimId ));
queryDataSource2.addSelectionField(fieldnuminventSumpostedQty ), selectionField::Sum);
queryDataSource2.addSelectionField(fieldnuminventSumreceived ), selectionField::Sum);
queryDataSource2.addSelectionField(fieldnuminventSumdeducted ), selectionField::Sum);
queryDataSource2.addSelectionField(fieldnuminventSumregistered ), selectionField::Sum);
queryDataSource2.addSelectionField(fieldnuminventSumpicked ), selectionField::Sum);
queryrun = new sysqueryrun(query);
queryRun.origQueryPack(query.pack(false));
Старый 24.10.2006, 13:36   #22
Protey is offline
Protey
Объясните плиз недалекому, что я не так делаю, не хочет у меня по строкам гулять цикл
while (queryrun.next())
Прикрепляю класс
Тип файла: xpo Test_Query.xpo (4.7 Кб, 384 просмотров)
Старый 24.10.2006, 13:43   #23
tricky is offline
tricky
140 / 64 (3) ++++
Тут надо бы глянуть на сам Query.
Старый 24.10.2006, 13:48   #24
Ну, во-первых, вы не прикрепили еще и запрос TestQuery
Насколько я понял из кода метода run() - там 3 таблицы связанных.
С запросом думаю все ОК.
С классом тоже.
В методе run выводятся и 3 и 4.
Думаю проблема, скорее всего, в настройках пользователя.
Измените CurrentVersion в ClassDeclaration на 2, и попрбуйте заново.
Если же все равно не будет работать, выкладывайте еще и сам запрос.
Старый 24.10.2006, 13:49   #25
Protey is offline
Protey
Выкладываю
Тип файла: xpo Test_Query (1).xpo (13.0 Кб, 378 просмотров)
Старый 24.10.2006, 13:52   #26
Protey is offline
Protey
Смена CurrentVersion не помогла
Старый 24.10.2006, 13:55   #27
Поможет, поможет.
Перекомпилируйте пару раз, а Version1 вообще можно удалить
Можете поставить точку останова в коде метода unpack и проконтролировать, что он прошел мимо #CurrentVersion
Старый 24.10.2006, 13:57   #28
George Nordic is offline
George Nordic
Аватар для George Nordic
4,480 / 1255 (50) ++++++++
Записей в блоге: 9
Сбросьте настройки пользователя: Тул-бар - Настройка - Параметры - Использование данных - сброс.
С Уважением,
Георгий
Старый 24.10.2006, 13:57   #29
tricky is offline
tricky
140 / 64 (3) ++++
У Вас в Relations источника данных InvebtSum неверная связь InventTable.ItemGroupId == InventSum.ItemId
За это сообщение автора поблагодарили: Protey (1).
Старый 24.10.2006, 13:59   #30
А что это за запрос у вас такой: ???
SELECT ItemId, ItemGroupId, INVALID FIELD, INVALID FIELD
FROM InventTable GROUP BY InventTable.ItemId ASC, InventTable.ItemGroupId ASC, InventTable.INVALID FIELD ASC, InventTable.INVALID FIELD ASC
JOIN SUM(PostedQty), SUM(Received), SUM(Deducted), SUM(Registered), SUM(Picked)
FROM InventSum WHERE InventTable.ItemGroupId = InventSum.ItemId
JOIN inventDimId, InventLocationId FROM InventDim GROUP BY InventDim.inventDimId ASC WHERE InventSum.InventDimId = InventDim.inventDimId
Опередили.
Старый 24.10.2006, 14:04   #31
Protey is offline
Protey
Блин, а слона то я и не заметил, все грешил на класс, а в query даже не смотрел, точно помню что в relations ставил связь InventTable.ItemId == InventSum.ItemId
Старый 24.10.2006, 14:09   #32
AndyD is offline
AndyD
КОРУС Консалтинг
2,560 / 2480 (88) +++++++++
Надо было сделать Relations=YES на подключаемом источнике данных - связь подставилась бы автоматом
Axapta v.3.0 sp5 kr2
Старый 24.10.2006, 14:10   #33
Protey is offline
Protey
Всем спасибо!
Наконец-то заработало!!!
Старый 24.10.2006, 14:20   #34
Protey is offline
Protey
Опередили.
А как из query выдернуть такой запрос, в виде select?
Старый 24.10.2006, 14:22   #35
info(qr.query().dataSourceNo(1).toString());
Вопрос по модулю Расчеты с персоналом. Выплата заработной платы. Keks DAX: Функционал 7 28.12.2009 10:31
Вопрос по перегрузке лукапа поля прям на таблице HorrR DAX: Программирование 3 03.06.2008 18:02
Вопрос по Проектам PSA DAX: Функционал 35 19.01.2007 22:26
расчеты с персоналом. НДФЛ. вопрос чайника shumelka DAX: Функционал 2 25.03.2004 11:36
Вопрос по счетам на оплату поставщикам sergey_alekseev DAX: Функционал 11 26.08.2003 19:43
Часовой пояс GMT +3, время: 09:02.
