Старый 20.09.2011, 23:12   #1
25,526 / 847 (80) +++++++
emeadaxsupport: Installation of Microsoft Dynamics AX 2009 or 2012 client may fail on a Microsoft Windows 7 x64 (64-bit operating system)
Источник: http://blogs.msdn.com/b/emeadaxsuppo...ng-system.aspx
Recently we come over some issues regarding the installation of the Microsoft Dynamics AX 2009 and 2012 Client on Microsoft Windows 7 x64 (64-bit operating system).
Retrieving the AXsetup logs we found there was a “component32.log” generated and not the expected “component64.log”.
In the “component32.log” we found the lines describing the error:
Action ended 08:09:19: AppSearch. Return value 1.
Action start 08:09:19: LaunchConditions.
MSI (s) (4C:0C) [08:09:19:298]: Product: Microsoft Dynamics AX 2009 Components (32 bit) -- Installation not supported on x64 processor.
We found the problem to be caused because the 64 bit .NET framework was disabled in the registry
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\.NETFramework\Enable64Bit
The default value for this key is 1, yet on this case it was set to 0, forcing framework applications to run in a 32-bit environment.
To change the value open a command prompt and and run the program below to enable and start the 64 bit .NET Framework.
(NOTE: Setting the registry value to 1 manually requires a reboot to start the 64 bit .NET framework)
C:\Windows\Microsoft.NET\Framework64\v2.0.50727\Ldr64.exe set64
loading kernel32...done.
retrieved GetComPlusPackageInstallStatus entry point
retrieved SetComPlusPackageInstallStatus entry point
Setting status to: 0x00000001
SUCCESS
Afterwards we were able succesfully complete AXSetup.
For more information on another reported issue that can also stop you from installing the AX 2009 client when using .NET Framework 4, see http://support.microsoft.com/kb/2290614 for more details.
--author:Uwe Zimmerman--editor:Jago van der Most, Anup Shah--date:20/09/2011
axforum blogs: Квест: Подружим Dynamics Ax 2009 Sp1 RU7 c SharePoint Foundation 2010 Blog bot DAX Blogs 4 16.10.2017 17:50
DynamicsAxSCM: Operational Sites in Microsoft Dynamics AX 2012 Blog bot DAX Blogs 0 25.05.2011 19:11
Rahul Sharma: Install Microsoft Dynamics AX 2009 SP1 on Windows 7 Blog bot DAX Blogs 0 04.05.2011 21:13
dynamics-ax: Interview with Microsoft's Lachlan Cash on his new role, AX 2012 and more Blog bot DAX Blogs 6 22.04.2011 14:55
Developer for Microsoft Dynamics AX Certification Roadmap Blog bot DAX Blogs 1 13.05.2009 16:17
Часовой пояс GMT +3, время: 12:17.
