Старый 22.08.2011, 10:11   #1
25,644 / 848 (80) +++++++
daxmusings: X++ in the .NET CLR : Life in the Fast Lane
Источник: https://community.dynamics.com/produ...fast-lane.aspx
You've heard it by now. In Dynamics AX 2012, X++ can actually run in the .NET CLR. What I've often heard is "X++ running on the server runs in IL". Well, that is somewhat true. But it doesn't mean setting your classes or menu items...(read more)
emeadaxsupport: When browsing AX 2009 Role Centers, you get an error: An unexpected error has occurred on systems with .NET Framework v4.0 installed Blog bot DAX Blogs 1 28.07.2010 08:24
AX.NET: интеграция .NET-приложений с Аксаптой и (будущие) возможности облачных вычислений gl00mie DAX: Программирование 2 23.04.2010 00:47
jinx: Microsoft Dynamics AX - X++ und .NET (CLR) Arrays Blog bot DAX auf Deutsch 0 03.03.2009 03:08
Dynamics AX: DAXguy - DAX and the .Net CLR Blog bot DAX Blogs 0 27.10.2007 04:23
Inside Dynamics AX 4.0: Working with the .NET Business Connector Blog bot DAX Blogs 0 04.10.2007 05:15
Часовой пояс GMT +3, время: 01:37.
