Старый 31.05.2013, 11:11   #1
Vadik is offline
Vadik
Аватар для Vadik
3,631 / 1853 (69) ++++++++
Hotfix 2845539 is available to provide an AIF Windows Azure Service Bus Adapter for services in Microsoft Dynamics AX 2012 R2
Microsoft Dynamics AX Application Integration Framework (AIF) is updated to support publishing Microsoft Dynamics AX services to the Cloud by using an AIF Windows Azure Service Bus Adapter. Microsoft Dynamics AX services can currently be published to IIS. However, these services are only accessible over a local network.
This hotfix enables compatibility between Microsoft Dynamics AX AIF and the Windows Azure Service Bus. It allows mobile and Cloud-based applications to communicate with a Microsoft Dynamics AX instance over the Internet.
Using the AIF Windows Azure Service Bus Adapter, Microsoft Dynamics AX services are hosted in IIS and configured to listen to service messages from the Service Bus. The Service Bus acts as a relay that makes building external applications that integrate with Microsoft Dynamics AX easier. Network configuration is not required to allow incoming messages to reach Microsoft Dynamics AX services for messages that are sent through the Service Bus.
For more information about the hotfix (including a functional overview, prerequisites, and configuration instructions), go to the following Microsoft website:
Microsoft Dynamics AX Services and Windows Azure Service Bus
http://support.microsoft.com/kb/2845539
-ТСЯ или -ТЬСЯ ?
За это сообщение автора поблагодарили: gl00mie (2).
aif, azure, ax2012
emeadaxsupport: Translated User Help on TechNet and downloadable New Features lists available! Blog bot DAX Blogs 0 31.01.2013 05:11
emeadaxsupport: Preliminary Microsoft Dynamics AX 2012 R2 content now on TechNet and MSDN! Blog bot DAX Blogs 0 10.11.2012 08:20
Sample Design Patterns: Book Give-away: 'Microsoft Dynamics AX 2012 Development Cookbook' Blog bot DAX Blogs 1 12.05.2012 16:55
dynamics-ax: Microsoft Highlights New ERP Public Sector Capabilities for AX 2012 Blog bot DAX Blogs 0 23.05.2011 19:11
Часовой пояс GMT +3, время: 10:40.
