Старый 06.08.2016, 03:27   #1
25,644 / 848 (80) +++++++
organicax: WMS work grouping at released to warehouse based on item
Источник: https://organicax.com/2016/08/05/wms...based-on-item/
In a previous post we had a look at splitting work based on the sales order number. In this next example we used the work breaks on the work template to break the work based on the item number. This might be more efficient in some cases depending on how the goods are physically laid out in the warehouse. In this case you could dispatch 3 workers to collect each a different item and return to a staging areas. This might be more efficient than the 3 workers each going to the 3 different item locations.
Here is a quick overview.
AX2012 R3 CU10
Cheers
Lachlan
Filed under: Warehouse management
DynamicsAxSCM: Migration of Microsoft Dynamics AX WMS to new R3 warehouse and transportation functionality Blog bot DAX Blogs 0 17.08.2015 20:19
DynamicsAxSCM: WHS Work List Blog bot DAX Blogs 0 19.06.2015 15:11
DynamicsAxSCM: Warehouse Mobile Device Portal Blog bot DAX Blogs 0 23.02.2015 22:12
wiki.dynamicsbook: Changes Made in Navision Attain 3.60 Blog bot Dynamics CRM: Blogs 0 02.09.2008 13:23
Вопрос про Demand Planner slava09 DAX: Функционал 4 25.09.2006 11:43
Часовой пояс GMT +3, время: 07:54.
