Старый 31.07.2018, 23:16   #1
25,644 / 848 (80) +++++++
d365technext: Batch Multi threading D365FO AX7
Источник: http://d365technext.blogspot.com/201...365fo-ax7.html
Normally, when we schedule our RunBaseBatch class as a batch job, it will create single task. Which will responsible to execute complete process in single thread.
But, As you know like AX-2009 and AX-2012. In D365FO We can add multiple AOS server in single batch group and they can process the multiple task simultaneously.
In this demo I will show, How to create multi threading Batch job.
following are the steps
Step-1 Create a table for demo purpose in our demo we keep table name is SLD_DemoTable.
Step-2 create a class with name SLD_DemoBusinessLogic and write your business logic in this class.
In demo I write only insert records in table and show you guys how it works.
Reference Code
class SLD_DemoBusinessLogic
public void processInit(VendTable _vend)
SLD_DemoTable SLDDemoTable;
SLDDemoTable.clear();
SLDDemoTable.VendName=_vend.name();
SLDDemoTable.VendAccount=_vend.AccountNum;
SLDDemoTable.insert();
Step-3 create a batch job class with name SLD_DemoMultiThreadTask.
This class we will use as Task in main batch job.
Step-4 In this class We Create a getter setter to store vend table buffer;
Step-5 Create object of our business logic class and execute method
Reference Code
public class SLD_DemoMultiThreadTask extends RunBaseBatch
VendTable ventTableBuffer;
#DEFINE.CurrentVersion(1)
#LOCALMACRO.CurrentList
ventTableBuffer
#ENDMACRO
public ClassDescription caption()
ClassDescription ret;
ret = 'Update Multiple Thread task';
return ret;
container pack()
return [#CurrentVersion,#CurrentList];
public boolean unpack(container _packedClass)
int version = conPeek(_packedClass,1);
switch (version)
case #CurrentVersion:
[version,#CurrentList] = _packedClass;
break;
default:
return false;
return true;
public void pramVendBuffer(VendTable _vend)
ventTableBuffer=_vend;
public void run()
try
SLD_DemoBusinessLogic SLDDemoBusinessLogic=new SLD_DemoBusinessLogic();
SLDDemoBusinessLogic.processInit(ventTableBuffer);
catch
info(strFmt("%1",xSession::xppCallStack()));
Step-6 Now Create main batch job which will responsible to create multiple task in single batch job.
Reference Code
class SLD_DemoMultiThreadBatch extends RunBaseBatch
BatchHeader batchHeader;
VendTable vendTable;
public static void main(Args args)
SLD_DemoMultiThreadBatch objMultiThread = new SLD_DemoMultiThreadBatch();
if (objMultiThread.prompt())
objMultiThread.run();
void run()
SLD_DemoMultiThreadTask SLDDemoMultiThreadTask;
try
while select firstonly10 vendTable
if(this.isInBatch())
if(!batchHeader)
batchHeader = BatchHeader::construct(this.parmCurrentBatch().BatchJobId);
batchHeader.parmCaption("Multiple thread batch jobs");
SLDDemoMultiThreadTask = new SLD_DemoMultiThreadTask();
SLDDemoMultiThreadTask.pramVendBuffer(vendTable.data());
// add tasks to the batch header
batchHeader.addRuntimeTask(SLDDemoMultiThreadTask, this.parmCurrentBatch().RecId);
else
// execute your code here when not running in batch
if(batchHeader)
// save the batchheader with added tasks
batchHeader.save();
catch
public container pack()
return conNull();
public boolean unpack(container packedClass)
return true;
Step-7 Now create an Action menu item and reference our batch job SLD_DemoMultiThreadBatch .
Step-8 Build and sync database and module and run the job.
Step-9 Navigate to you batch job page and find your job and check Job Task.
Step-10 before execution of the batch job check the demo table.
you can check the below screen shot currently table is empty.
After execution of the job table filled with vendors names.
Please feel free to contact me if you are facing any issue during implementation of this blog
stoneridgesoftware: How to Enable Multi-Factor Authentication for the New Dynamics AX (Dynamics AX7) Blog bot DAX Blogs 0 22.09.2016 00:11
patrickmouwen: AX7 – My top 12 highlights Blog bot DAX Blogs 0 27.02.2016 13:11
Axilicious:Business Operation Framework and multi-threading Blog bot DAX Blogs 0 25.02.2012 05:42
axinthefield: Optimizing AX Batch Performance - Batch Group Configuration Blog bot DAX Blogs 0 01.04.2011 13:11
axaptapedia: Batch processing Blog bot DAX Blogs 0 29.01.2009 17:05
Часовой пояс GMT +3, время: 00:57.
