Старый 06.02.2019, 07:12   #1
25,644 / 848 (80) +++++++
ievgensaxblog: MSDyn365FO. How to Import CSV file using Electronic Reporting. Part 3 – Map format to model.
Источник: https://ievgensaxblog.wordpress.com/...rmat-to-model/
In this blog post we will create new mapping to map format to model. On the format designer screen, click “Map format to model” button. Create new record, select model definition, specify name and description:
Open designer. In the designer bind Record List from the format to Record List in the model and then bind fields accordingly.
Finally, we can test our format. For the test I’m going to use simple CSV file:
Go back to Model to Datasource mapping form, click run in the action pane and upload the file.
If we’ve done everything right, we will get XML file that contains data mapped to model or errors, if any:
At this stage we have Data Model, Format and Mapping that we’ve tested. In the next blog post we will do the last piece of the setup – map Model to Destination and test the whole import.
ievgensaxblog: MSDyn365FO. How to Import CSV file using Electronic Reporting. Part 4 – Map Model to Datasource. Blog bot DAX Blogs 0 06.02.2019 07:12
dynamicsax-fico: Electronic Reporting: Import of GL Excel Journals (Part 1) Blog bot DAX Blogs 0 24.01.2019 14:11
powerobjects: Electronic Reporting in Dynamics 365 for Finance and Operations Blog bot DAX Blogs 0 14.02.2018 03:28
german_nav_developer: Buildnummern-Übersicht Microsoft Dynamics NAV 2013 Blog bot NAV: Blogs 0 15.05.2016 18:12
NAV Team: How to: Enable Import/Export of Bank or Payroll Files Using the Data Exchange Framework Blog bot Dynamics CRM: Blogs 0 18.10.2013 02:33
Часовой пояс GMT +3, время: 18:51.
