Старый 06.05.2014, 15:11   #1
vasantharivali: Add Query Range for Same Table with Different DataSources
Источник: http://vasantharivali.wordpress.com/...t-datasources/
Hi Friends,
Here I have posted the code(not entire job/program) for adding multiple ranges/relations with the same table using Query object
Code Starts Here:
QueryRun qr;
//1st DataSource
QueryBuildDataSource qbdTableSourcefromQuery; // get query from the AOT Query which used by System in SysQuery()
QueryBuildDataSource qbdTableSourcefromCode; // newly added Query for Account Number Range
qr = new QueryRun(“your Query”);
qbdCustTableSourcefromQuery = SysQuery::findOrCreateDataSource(qr.query(), tableNum(TableName1));
SysQuery::findOrCreateRange(qbdCustTableSourcefromQuery, fieldNum(TableName1, FieldName)).value(“QueryValue”);
//2nd DataSource
qbdCustTableSourcefromCode = qbdCustTableSourcefromQuery.addDataSource(tableNum(TableName1), “TableNameNew”);
qbdCustTableSourcefromCode.relations(true);
qbdCustTableSourcefromCode.joinMode(JoinMode::ExistsJoin);
qbdCustTableSourcefromCode.addRange(fieldNum(TableName1, FieldName)).value(queryValue(“QueryValue”));
// Vasanth Arivali
atinkerersnotebook: Using the Dynamics AX Excel Add-In Blog bot DAX Blogs 1 25.09.2013 07:11
emeadaxsupport: Dynamics AX 2012 Reporting: How to add company logo into query based report Blog bot DAX Blogs 0 06.12.2012 21:11
vasantharivali: Dynamic Query Using Aggregative Functions and Joins Blog bot DAX Blogs 0 17.11.2012 11:12
ax-erp: How to Set the Query Range on a SSRS Report Blog bot DAX Blogs 0 18.10.2012 19:11
Часовой пояс GMT +3, время: 09:02.
