#1 |
vasantharivali: Dynamic Query Using Aggregative Functions and Joins
Источник: http://vasantharivali.wordpress.com/...ons-and-joins/
============== Hi All, Here i written the code to use the Aggregate functions and Joins inDynamic Query in spite of using normal Select statement in Ax 2009 Normal Select Statement: while select sum(qty) from inventTrans where inventTrans.ItemId == “OL-2500” join inventDimgroup by inventBatchId where inventDim.InventDimId == inventTrans.InventDimId { // Our Code Here } Dynamic Query: static void Vasanth_Query_Eg1(Args _args) { Query query; QueryBuildDataSource queryBuildDataSource; QueryBuildRange queryBuildRange; QueryRun queryRun; Qty total; InventTrans inventTrans; ; query = new Query(); queryBuildDataSource = query.addDataSource(tableNum(InventTrans)); queryBuildDataSource.addSelectionField(fieldNum(InventTrans,Qty), SelectionField::Sum); queryBuildDataSource.orderMode(OrderMode::GroupBy); queryBuildRange = queryBuildDataSource.addRange(fieldNum(InventTrans,ItemId)); queryBuildDataSource = queryBuildDataSource.addDataSource(tableNum(InventDim)); queryBuildDataSource.orderMode(OrderMode::GroupBy); queryBuildDataSource.addSortField(fieldNum(InventDim,InventBatchId)); queryBuildDataSource.relations(true); queryRun = new QueryRun(query); if (queryRun.prompt()) { while (queryRun.next()) { inventTrans = queryRun.get(tableNum(InventTrans)); total = inventTrans.Qty; } } info(strFmt(“Quantity: %1″, total)); } ![]() Источник: http://vasantharivali.wordpress.com/...ons-and-joins/
Расскажите о новых и интересных блогах по Microsoft Dynamics, напишите личное сообщение администратору. |
