Старый 22.09.2016, 13:11   #1
organicax: Fixed Asset – create from project accounting
Источник: https://organicax.com/2016/09/21/fix...ct-accounting/
If you are acquiring a machine or building to improve your business you might accumulate costs associated with bringing that machine on and installing it to make it a useful asset. These costs you might be able to capitalize into the value of the asset. If you are using AX you can use the project management and accounting module to accumulate the costs like time, expenses etc. and then capitalize these as part of the asset through the project estimation.
Here is a quick look.
AX2012 R3 CU11
Cheers
Lachlan
Filed under: Fixed Assets, Microsoft Dynamics AX, Project management and accounting
organicax: Fixed Asset create from inventory Blog bot DAX Blogs 0 20.09.2016 10:11
organicax: Create a fixed asset through a purchase order. Blog bot DAX Blogs 0 20.09.2016 10:11
organicax: Basic fixed asset create process. Blog bot DAX Blogs 0 20.09.2016 10:11
emeadaxsupport: Intercompany time postings incomplete at transaction voucher level when project date differs from the day posted Blog bot DAX Blogs 0 19.08.2013 19:11
Часовой пояс GMT +3, время: 19:16.
