Старый 20.09.2016, 10:11   #1
25,644 / 848 (80) +++++++
organicax: Basic fixed asset create process.
Источник: https://organicax.com/2016/09/19/bas...reate-process/
If you are starting to work with AX then you will note it has a mot of modules that you can make use of. One of these is a fixed asset module which has reasonable good capabilities to manage the financial aspects of fixed assets. It’s not an assets maintenance module it’s designed to track the depreciation about the assets. There are a lot of parameters to control the books to manage the depreciation but to get you started you might want to have a look at a basic process of creating an asset and bringing it onto the system financially.
Here is a quick overview.
AX2012 R3 CU11
Cheers
Lachlan
Filed under: Fixed Assets, General ledger
organicax: Fixed Asset create from inventory Blog bot DAX Blogs 0 20.09.2016 10:11
organicax: Create a fixed asset through a purchase order. Blog bot DAX Blogs 0 20.09.2016 10:11
organicax: Basic process for foreign currency revaluation on an account Blog bot DAX Blogs 0 25.03.2016 05:29
organicax: Basic request for quotation process Blog bot DAX Blogs 0 15.03.2016 04:48
wiki.dynamicsbook: Changes Made in Navision Attain 3.60 Blog bot Dynamics CRM: Blogs 0 02.09.2008 13:23
Часовой пояс GMT +3, время: 03:22.
