Старый 31.03.2017, 19:12   #1
organicax: Connecting your LCS project with your D365 installation
Источник: https://organicax.com/2017/03/31/con...-installation/
When you do a new install of D365 it will have been done through LCS. So you would have created a project to manage the deploy you could use that or another project to manage the implementation documents and procedures. So after you have deployed then you should go into the system administration to change the help settings to select the project you want to work with.
This is important if you later want to deploy artifacts from LCS for example PowerBI or update task recordings to the BPM library.
Here is a quick overview.
D365FO
Cheers
Lachlan
Filed under: Lifecycle Services
lcs
organicax: Setting up budget control parameters in project accounting Blog bot DAX Blogs 0 01.02.2017 05:22
organicax: Setting up LCS and a machine for data template and config manager. Blog bot DAX Blogs 0 31.10.2016 22:11
organicax: cXML punchout protocol handler installation for AX2012 R3 Blog bot DAX Blogs 0 27.09.2016 14:11
organicax: Fixed Asset – create from project accounting Blog bot DAX Blogs 0 22.09.2016 13:11
emeadaxsupport: Intercompany time postings incomplete at transaction voucher level when project date differs from the day posted Blog bot DAX Blogs 0 19.08.2013 19:11
Часовой пояс GMT +3, время: 15:32.
