Старый 31.10.2016, 22:11   #1
organicax: Setting up LCS and a machine for data template and config manager.
Источник: https://organicax.com/2016/10/31/set...onfig-manager/
I did a couple of post on the data template and the config manager to see the basic process of exporting data from a configuration. The usage of these require the system diagnostics service which you can find a post here. There are some additional parameters that you will need to configure on the system diagnostics which you can find documented there
Set up Configuration manager (Lifecycle Services, LCS)</p>
Here is a quick overview of these parameter to put them in context.
AX2012 R3 CU11
Cheers
Lachlan
Filed under: Data migration, Lifecycle Services
Часовой пояс GMT +3, время: 08:57.
