Старый 31.07.2018, 17:11   #1
d365technext: Task Recorder D365FO
Источник: http://d365technext.blogspot.com/201...er-d365fo.html
In D365FO Microsoft Introduce a really built in tool Task recording. its allow us to record the step even we can save the steps as documentation.
with simple following steps you can use Task recording as well.
As the following picture shows, the Task Recorder is found under Settings: in the ribbon:
Once in the Task Recorder, you have the options to create a new recording, play back a recording or edit an existing recording as the following picture show.
Let us start by recording a new Task.
Give the guide a descriptive name and press the Start button.
The task recorder is now in recording mode. You can stop the recording by clicking on the Stop button in the ribbon.
I would like to structure my Task Guide in sections, so I start my creating a sub-task:
In my demo i am performing some action and you can check in the screen shot Task recorder is recording every steps.
Like
1st I closed a open page
2nd open Worker from payroll
Step-1
Step-2
Step-3 Stop
There are two options available to save record.
Word documentation
Save file in AXtr format.
stoneridgesoftware: Working with Task Recorder and Task Guide in New Microsoft Dynamics AX Blog bot DAX Blogs 0 27.05.2016 00:16
Microsoft Dynamics CRM Team Blog: Creating and customizing task flows Blog bot Dynamics CRM: Blogs 0 11.12.2015 04:14
atinkerersnotebook: Use Your Own Personalized Template When Creating Documents From The Task Recorder Blog bot DAX Blogs 0 06.02.2014 22:11
atinkerersnotebook: Creating Lifecycle Services Business Process Models with the Task Recorder Blog bot DAX Blogs 0 08.12.2013 19:12
tlefor: Dynamics AX2012: Integrating Managed Controls with Task Recorder Blog bot DAX Blogs 0 28.10.2013 10:11
Часовой пояс GMT +3, время: 05:25.
