Старый 06.02.2014, 22:11   #1
25,644 / 848 (80) +++++++
atinkerersnotebook: Use Your Own Personalized Template When Creating Documents From The Task Recorder
Источник: http://atinkerersnotebook.com/2014/0...task-recorder/
Reblogged from Dynamics AX Tip Of The Day:
The task recorder is great because it practically creates all of your user documentation for you.  The only problem is that the format of the documentation that it created is a little bland.  Don’t worry though, rather than reformat all of the documents that are created after the fact, you have the option to change the default template that is used when the documents are created.
Read more… 245 more words
atinkerersnotebook: Creating Lifecycle Services Business Process Models with the Task Recorder Blog bot DAX Blogs 0 08.12.2013 19:12
atinkerersnotebook: Using PowerPivot to Analyze Dynamics AX Data Blog bot DAX Blogs 1 05.10.2013 07:23
atinkerersnotebook: Creating Your Own Document Management System With SharePoint Blog bot DAX Blogs 0 02.10.2013 21:12
atinkerersnotebook: Using Service Management to Track Service Orders Blog bot DAX Blogs 1 25.08.2013 19:16
Часовой пояс GMT +3, время: 00:22.
