Старый 01.12.2011, 18:11   #1
palleagermark: Hiding a data member attribute from dialogs
Источник: http://palleagermark.blogspot.com/20...bute-from.html
When you use data contracts with for example the new Business Oprations Framework (BOF), it is smart that AX will generate the dialog for you. But what if you have a field in the data contract that you don't want exposed in the dialog?
Well, use the SysOperationControlVisibilityAttribute:
[DataMemberAttribute, SysOperationControlVisibilityAttribute(false)]
public int parmIntProperty(int _parmIntProperty = parmIntProperty)
parmIntProperty = _parmIntProperty;
return parmIntProperty;
Microsoft Dynamics CRM Team Blog: Create Sample Data for your Solution Blog bot Dynamics CRM: Blogs 0 01.12.2011 05:14
Microsoft Dynamics CRM Team Blog: Transferring Data from One CRM Organization to Other Organization Blog bot Dynamics CRM: Blogs 0 23.03.2011 19:11
palleagermark: Parsing a custom parameter from a user control to a data set used on another user control Blog bot DAX Blogs 0 28.10.2010 12:05
Microsoft Dynamics CRM Team Blog: Data Migration Manager Tips and Tricks Blog bot Dynamics CRM: Blogs 0 02.09.2008 22:05
palleagermark: Read data from other databases Blog bot DAX Blogs 5 11.06.2008 11:42
Часовой пояс GMT +3, время: 00:20.
