#1 |
Microsoft Dynamics CRM Team Blog: Transferring Data from One CRM Organization to Other Organization
Источник: http://blogs.msdn.com/b/crm/archive/...anization.aspx
============== Many a times you would have the need to transfer data from one Microsoft Dynamics CRM organization to another for some record type. This blog covers the steps you can follow to move data from one organization to another using Import Wizard. Let us take example that you want to move data for Account and Contact record types. 1. Create a view of all fields for the record type Account. a. Go to accounts Grid and click on Create personal view ![]()
a) Go to Accounts Grid. ![]() d) Select “Static worksheet with records from all pages in current view”. ![]() e) Click Export and save the file. (Account.xls)(The records that are exported will be based on the record for which you had privileges).Note: Do not check make this data available for reimport checkbox as this feature is meant to export and update data in the same organization and not for cross organization data migration. 2: Similarly export the data for Contact record type and save as CSV/XMLSS file.(Contact.csv). 3: Zip the two files in a single Zip file (ExportedData.zip). 4: Use Import Wizard to Import the file
![]() As the file names match with the Record type display name in this example so files will be automatically mapped. (Map the files with respective record types if they are not auto mapped.)
Dinesh Kumar Garg Источник: http://blogs.msdn.com/b/crm/archive/...anization.aspx
Расскажите о новых и интересных блогах по Microsoft Dynamics, напишите личное сообщение администратору. |
