organicax: Setting up a new expense category and GL account
Источник: https://organicax.com/2016/10/11/set...nd-gl-account/
============== If you are looking to use AX for coordinating some of your purchasing of expense there is a lot of functionality in AX to control the process. Some of the things that you will need to setup are a category if you don’t want to track inventory related to the purchase and a GL account to post to. You can link the two through the inventory posting setup. Here is a quick overview. AX7 Build 7.0.4230.16130 If you are working with AX2012 you can get an overview here. Cheers Lachlan Filed under: Accounts payable, Procurement and sourcing ![]() Источник: https://organicax.com/2016/10/11/set...nd-gl-account/
