Старый 12.10.2016, 06:25   #1
organicax: Setting up a new expense category and GL account
Источник: https://organicax.com/2016/10/11/set...nd-gl-account/
If you are looking to use AX for coordinating some of your purchasing of expense there is a lot of functionality in AX to control the process. Some of the things that you will need to setup are a category if you don’t want to track inventory related to the purchase and a GL account to post to. You can link the two through the inventory posting setup.
Here is a quick overview.
AX7 Build 7.0.4230.16130
If you are working with AX2012 you can get an overview here.
Cheers
Lachlan
Filed under: Accounts payable, Procurement and sourcing
organicax: AP Invoice workflow post before or after approval Blog bot DAX Blogs 0 07.10.2016 15:11
organicax: Approved flag on vendor invoices Blog bot DAX Blogs 0 07.10.2016 09:11
organicax: Vendor invoice with working, matching test and posting to GL Blog bot DAX Blogs 0 01.10.2016 04:15
dynamicsax-fico: A note on vendor cash discount posting options Blog bot DAX Blogs 0 04.05.2016 00:15
dynamicsax-fico: Earned Value Management (2) Blog bot DAX Blogs 0 16.03.2016 12:11
Часовой пояс GMT +3, время: 15:58.
