Различия между 3.0 и 4.0
Где в наиболее полном объеме можно почитать о различиях между 3.0 и 4.0?
злыдень
Нет, я просто тащусь от этой компании ))
По приведенной мази ссылке, цитирую: Цитата:
Direct SQL
When direct SQL is used through the Connection and Statement classes, it is subject to SQL injection threats. Classes that wrap these kernel classes—for example, the SysSQLBuilder classes—are equally dangerous. You should keep in mind that record-level security and field-level security are not enforced on the Statement class. To learn more about SQL injection attacks, see the article, Stop SQL Injection Attacks Before They Stop You, on MSDN. Открываем Читвёртую Аксапту, и что мы там видим? Правильно! Прямой SQL))) X++: /* This method will build following statement in a str:
execute sp_executesql N'UPDATE InventSum
SET InventSum.CostAmountPhysical = InventSum.CostAmountPhysical +
InventSumDelta.SUM_CostAmountPhysical,
InventSum.PostedValue = InventSum.PostedValue +
InventSumDelta.SUM_PostedValue,
InventSum.Qty = InventSum.Qty +
InventSumDelta.SUM_Qty,
InventSum.LastUpdDatePhysical = CASE WHEN InventSum.LastUpdDatePhysical > InventSumDelta.MAX_LastUpdDatePhysical
THEN InventSum.LastUpdDatePhysical
ELSE InventSumDelta.MAX_LastUpdDatePhysical
END,
InventSum.LastUpdDateExpected = CASE WHEN InventSum.LastUpdDateExpected > InventSumDelta.MAX_LastUpdDateExpected
THEN InventSum.LastUpdDateExpected
ELSE InventSumDelta.MAX_LastUpdDateExpected
END,
InventSum.ClosedQty = CASE WHEN ((InventSum.PostedQty + InventSumDelta.SUM_PostedQty) = 0 AND
(InventSum.Deducted + InventSumDelta.SUM_Deducted) = 0 AND
(InventSum.Picked + InventSumDelta.SUM_Picked) = 0 AND
THEN 1
ELSE 0
END,
InventSum.Closed = CASE WHEN ((InventSum.PostedValue + InventSumDelta.SUM_PostedValue) = 0 AND
(InventSum.PhysicalValue + InventSumDelta.SUM_PhysicalValue) = 0 AND
THEN 1
ELSE 0
END
FROM (SELECT SUM(CostAmountPhysical) AS SUM_CostAmountPhysical,
SUM(PostedValue) AS SUM_PostedValue,
SUM(Qty) AS SUM_Qty,
..... AS ...,
..... AS ...,
MAX(LastUpdDatePhysical) AS MAX_LastUpdDatePhysical,
MAX(LastUpdDateExpected) AS MAX_LastUpdDateExpected,
InventSumDelta.ItemId,
InventSumDelta.InventDimId
FROM InventSumDelta
WHERE InventSumDelta.DataAreaId = @p1
AND InventSumDelta.TTSId = @p2
AND InventSumDelta.IsAggregated = 0
GROUP BY InventSumDelta.ItemId, InventSumDelta.InventDimId
) AS InventSumDelta
WHERE InventSum.DataAreaId = @p1
AND InventSum.ItemId = InventSumDelta.ItemId
AND InventSum.InventDimId = InventSumDelta.InventDimId
',N'@p1 NVARCHAR(3), @p2 BIGINT',@p1=%1, @p2='%2'
Ибо зло есть лучшая сила человека. "Человек должен становиться все лучше и злее" -- так учу я. /Ф. Ницше/ |
Да ладно вам! Радоваться надо: люди работают, ускоряют медленные запросы.
злыдень
Да пусть работают, я разве против?? ))
#6 |
Microsoft Dynamics
Сообщение от Recoilme
#7 |
Ля-ля-ля - не юзайте прямой SQL пока он не поюзал Вас.
Not registered yet? Register here! Have comments, questions, suggestions or anything else regarding our web site? Don't hesitate, send them to me |
#8 |
А есть у кого-нибудь документация по Ax 4.0?
#9 |
злыдень
Сообщение от Maxim Gorbunov
Ну и где там это написано? Что-то уж больно художественный перевод у Вас получился
![]() Честно говоря, настораживает почему то.. Может читсо теоретически пояснит кто, как это работает (ИМТС в 4) ??? ??? ???
#10 |
#11 |
Dynamics 365 MR
Сообщение от klo
![]() для партнеров доступны описания нового в АХ в функциональности и технологиях, 600 и 200 страниц соответственно. Все есть на PartnerSource |
#12 |
дайте плиз ссылку на PartnerSource, где все это лежит, если не сложно.
доступ есть. |
#13 |
Dynamics 365 MR
#14 |
Спасибо.
#15 |
А когда будет доступна информация для простых людей-не партнеров?
Или может уже что-то есть в свободном доступе? |
#16 |
Сообщение от fomenka
Или может уже что-то есть в свободном доступе? Axapta 4.0. Когда? См. также http://forum.mazzy.ru/index.php?s=&s...ndpost&p=23177 |
#17 |
Спасибо за ссылки, mazzy. Но все это прочитано уже. Вот если бы были опубликованы те самые 600+200 страниц, вот это было бы интересно! Неизвестно ничего о планах MBS в этой области? Не для партнеров, а для простых легальных пользователей Axapta?
Последний раз редактировалось fomenka; 08.08.2006 в 15:10. |
#18 |
Dynamics 365 MR
fomenka, после перевода данных документов на русский язык, они будут опубликованы на клиентском портале.
#19 |
"Для простых легальных пользователей" в России Аксапта еще не появилась. То, что сейчас обсуждается - американский релиз. |
#20 |
Dynamics 365 MR
