Старый 27.05.2007, 12:15   #2
Maxim Gorbunov is offline
Maxim Gorbunov
2,483 / 646 (26) +++++++
Most likely the number sequence you are using for journal numbering is set up as continuous. You'll find this setting on the General tab page in the Number sequences form.
If a number sequence is set up as continuous, Axapta tries to avoid gaps in numbering. Assume you've created a new journal but then you've decided to delete it without saving. If the number sequence is not continuous then when you create a new journal, next number will be used. If the number sequence is continuous, Axapta will use the same number for a new journal since this number was not used (you haven't actually saved the record).
За это сообщение автора поблагодарили: ginmur (1).
daxcoder: Number Sequence Framework Part I Blog bot DAX Blogs 0 31.01.2008 15:00
Куда пропадают лицензии в Ax3.0 SP3 KR2? falcon65 DAX: Администрирование 2 10.05.2007 09:55
Arijit Basu: New Number Sequence for new AX Module Blog bot DAX Blogs 1 16.04.2007 10:39
Ax3.0 SP3 CIS: Журнал накладных и российские договора (ошибка) mpa DAX: Функционал 2 11.10.2004 15:14
Warning: Number sequence for network is not initialized Mish DAX: Администрирование 13 02.07.2003 15:40
Часовой пояс GMT +3, время: 23:36.
