#10 |
Есть такая засада:
Specifications for Tables Range for table object ID numbers : 1 -999,999,999 (A) Maximum number of characters in a table name : 30 Maximum table size : Infinite Maximum number of records in a table : Infinite Maximum record size : 4000 Maximum number of fields in a record : 500 Range for field numbers : 1 - 999,999,999 Maximum number of keys for a table : 40 Maximum number of distinct fields per key 20 for a primary key. The number of fields in the primary key + the number of fields in a secondary key which do not occur in the primary key must always be less than or equal to 20. Maximum number of SumIndexFields per key : 20 Maximum number of characters in a text or code field : 250 Maximum size of a BLOB field : 2 GB Maximum number of characters in a field name : 30 Возможно, стоит использовать вычисляемые поля? |
