Старый 20.01.2008, 08:14   #1
Solutions Monkey: SharePoint Tips & Tricks
Источник: http://blogs.msdn.com/solutions/arch...ps-tricks.aspx
1) If you are building a web part and is crashing the webpage, here is a quick way to remove it and get the rest of the page working.Add contents=1 to for example, if the page url is http://axep/default.aspx then change it to http://axep/default.aspx?content=1 and it will bring up the web part page maintenance page and lists all the webparts that are used in that page and provides way to delete selected web parts , switch view or reset.
(2) If you are trying to access the SharePoint just with the site url without specifying default.aspx , for ex http://axep and instead of rendering the webpart page, if it gives a File download warning, check the Execute permission property of the IIS Web site. For the default page to be redirected from just the URL, the IIS web site should have execute permission set to “Scripts and Executables”
Solutions Monkey: Integrating EP Web Parts to non-EP SharePoint sites Blog bot DAX Blogs 0 04.04.2009 03:19
Solutions Monkey: Convergence session: Enterprise Portal Deployment Tips and tricks Blog bot DAX Blogs 0 26.03.2009 08:05
Solutions Monkey: Microsoft Dynamics AX 2009 Enterprise Portal / Role Centers - Deployment Tips-n-Tricks – 3 Blog bot DAX Blogs 0 27.10.2008 08:05
Solutions Monkey: Microsofty Dynamics AX 2009 Enterprise Portal / Role Centers - Deployment Tips-n-Tricks - 2 Blog bot DAX Blogs 0 30.09.2008 07:07
Solutions Monkey: Microsofty Dynamics AX 2009 Enterprise Portal / Role Centers - Deployment Tips-n-Tricks - 1 Blog bot DAX Blogs 0 26.06.2008 09:05
Часовой пояс GMT +3, время: 08:57.
