#7 |
добавлю свои пять копеек
кусок кода из класса печати этикеток, преобразует репорт дизайн в EPL для печати напрямую этикеточный принтер X++: void addSection(ReportSection _reportSection, common _cursor) { ReportControl reportControl; ReportStringControl reportStringControl; SysDictClass classObj = new SysDictClass(classnum(ReportSection));// int childNodesCount; int i; ; childNodesCount = _reportSection.AOTchildNodeCount(); txt += "\nN\n"; for(i = 0; i < childNodesCount; i++) { reportControl = _reportSection.controlNo(i); if (! reportControl) continue; if (reportControl.controlType() == ReportFieldType::String) { reportStringControl = reportControl; if (reportStringControl.font() == "BC C128 Medium") { txt += "B" + this.position(reportControl.left100mm()/12, reportControl.top100mm()/12); this.addBarCode(reportControl, _reportSection, _cursor, classObj); txt += "\n"; continue; } } txt += "A" + this.position(reportControl.left100mm()/12, reportControl.top100mm()/12); switch (reportControl.controlType()) { case ReportFieldType::Text: this.addText(reportControl, _reportSection, _cursor, classObj); break; case ReportFieldType::String: this.addString(reportControl, _reportSection, _cursor, classObj); break; case ReportFieldType::Integer: this.addInteger(reportControl, _reportSection, _cursor, classObj); break; case ReportFieldType::Real: this.addReal(reportControl, _reportSection, _cursor, classObj); break; } txt += "\n"; } txt += "P1\n"; X++: void addString(ReportControl _reportControl, ReportSection _reportSection, common _cursor, SysDictClass _classObj) { ReportStringControl reportControl = _reportControl; str s; ; txt += this.font(reportControl.fontSize(), reportControl.bold(), reportControl.italic(), reportControl.font()); if (reportControl.dataField()) { s = _cursor.(reportControl.dataField()); } if (reportControl.dataMethod()) { s = _classObj.callObject(reportControl.dataMethod(), _reportSection); } s = strreplace(s, "\"","'"); txt += strfmt("\"%1\"", s); } могу весь класс выложить если кому интересно
aLL woRk aNd nO JoY MAKes jAck a dULL Boy |
Теги |
контрол, отчет |
