Старый 05.09.2008, 15:17   #1
custtable is offline
custtable
Аватар для custtable
29 / 10 (1) +
я использовал COM обект CDO.
вот ссылка на тему
E-mail в Аксапте 3.0 с помощью CDO.Message COM объекта
Старый 05.09.2008, 15:28   #2
custtable
29 / 10 (1) +
static void sendCDOMessage(Args _args)
        COM mailer, config, fields;
        COM item_SendUsing, item_SMTPServer, item_smtpserverport;
        COM item_SMTPAuthenticate, item_SMTPUsername, item_SMTPPassword;
        COMVariant comSendUsing = new COMVariant();
        COMVariant comSMTPServer = new COMVariant();
        COMVariant comSMTPServerPort = new COMVariant();
        COMVariant comSMTPAuthenticate = new COMVariant();
        COMVariant comSMTPUsername = new COMVariant();
        COMVariant comSMTPPassword = new COMVariant();
        mailer = new COM("CDO.Message");
        config = new COM("CDO.Configuration");
        config = mailer.configuration();
        fields = config.Fields();
        item_SendUsing = fields.Item("http://schemas.microsoft.com/cdo/configuration/sendusing");
        comSendUsing.int(2);
        item_SendUsing.Value(comSendUsing);
        item_smtpserver = fields.Item("http://schemas.microsoft.com/cdo/configuration/smtpserver");
        comSMTPServer.bStr('smtp.server.com');
        item_SMTPServer.Value(comSMTPServer);
        item_SMTPServerPort = fields.Item("http://schemas.microsoft.com/cdo/configuration/smtpserverport");
        comSMTPServerPort.int(25);
        item_SMTPServerPort.Value(comSMTPServerPort);
        item_SMTPAuthenticate = fields.Item("http://schemas.microsoft.com/cdo/configuration/smtpauthenticate");
        comSMTPAuthenticate.int(1); // 1 for true, DO authenticate
        item_SMTPAuthenticate.Value(comSMTPAuthenticate);
        item_SMTPUsername = fields.Item("http://schemas.microsoft.com/cdo/configuration/sendusername");
        comSMTPUsername.bStr('userId');
        item_SMTPUsername.Value(comSMTPUsername);
        item_SMTPPassword = fields.Item("http://schemas.microsoft.com/cdo/configuration/sendpassword");
        comSMTPPassword.bStr('password');
        item_SMTPPassword.Value(comSMTPPassword);
        fields.update();
        mailer.Configuration(config);
        mailer.From("somebody@somewhere.com");
        mailer.To("somebody@somewhere.com");
        mailer.Subject("Subject");
        mailer.TextBody("Body");
        mailer.Send();
        mailer = null;
Использование изображения в шаблоне электронной почты Vhaldemar DAX: Программирование 8 07.06.2012 18:04
Отправка почты через Outlook... lev DAX: Программирование 9 12.12.2008 13:27
CRM:отправка почты на Outlook fialka DAX: Функционал 2 17.06.2008 16:09
Отправка почты: ошибка с SysInetMailer axapta25Dev DAX: Программирование 20 11.03.2008 14:53
Параметры почты - не работает... soin DAX: Функционал 3 09.01.2004 01:00
Часовой пояс GMT +3, время: 07:10.
