Старый 04.03.2009, 15:24   #4
Eldar9x is offline
Eldar9x
Аватар для Eldar9x
1,064 / 166 (8) ++++++
Вот кстати, подробно:
The SelectForUpdate Method
Calling selectForUpdate(true) on a record buffer replaces the use of the forupdate keyword in a select statement. The following piece of X++ code
custTable.selectForUpdate(true);
select custTable where custTable.AccountNum == '4000';
is equal in behavior to this code.
[View full width]
select forupdate custTable where custTable
Depending on the concurrency model settings on the table, a NOLOCK or UPDLOCK hint is added to the SELECT statement parsed to SQL Server 2000.
Tip
If you use the Query framework instead of select statements to retrieve records, it is also possible to retrieve these records as if a forupdate keyword had been used by calling update(true) on the QueryBuildDataSource object.
http://doc.qiuhao.com/0735622574/ch12lev1sec7.html
Dianne Siebold: Rec Fields Required in AIF Partial Update Blog bot DAX Blogs 0 20.01.2009 09:05
DeniZone: Setting Cross-reference update in a Schedueld task Blog bot DAX Blogs 0 12.12.2008 13:05
epblog: How to update Data Set from User Control? Blog bot DAX Blogs 0 21.06.2008 13:05
Dianne Siebold: Update on the Dynamics AX SDK Team kashperuk DAX Blogs 1 16.10.2007 08:23
Часовой пояс GMT +3, время: 18:32.
