Старый 22.03.2009, 03:59   #1
S K is offline
S K
Можно написать свою маленькую программку и выполнить ее.
public static Guid RegisterStep(CrmService.CrmService crmService, Guid pluginTypeID, string entityName, Guid sdkMessageID)
        Guid sdkMessageFilterID = GetSdkMessageFilterID(crmService, entityName, sdkMessageID);
        if (sdkMessageFilterID == Guid.Empty)
            throw new Exception("Не удалось получить Guid messagefilter для EntityName = '" + entityName + "', sdkMessageID = '" + sdkMessageID + "'");
        sdkmessageprocessingstep step = new sdkmessageprocessingstep();
        step.plugintypeid = new Lookup();
        step.plugintypeid.Value = pluginTypeID;
        step.sdkmessagefilterid = new Lookup();
        step.sdkmessagefilterid.Value = sdkMessageFilterID;
        step.sdkmessageid = new Lookup();
        step.sdkmessageid.Value = sdkMessageID;
        step.description = "Auditing Plugin";
        step.invocationsource = new Picklist();
        step.invocationsource.Value = 0; // 0 (parent pipeline) or 1 (child pipeline)
        step.mode = new Picklist();
        step.mode.Value = Config.ModePluginExecution;
        step.rank = new CrmNumber();
        step.rank.Value = 0;
        step.stage = new Picklist();
        step.stage.Value = 50; // 10 (pre-event) or 50 (post-event)
        step.supporteddeployment = new Picklist();
        step.supporteddeployment.Value = 0; // 0 (server), 1 (Outlook client), or 2 (both)
        //Comma separated list of attributes that must be changed for the plug-in to be invoked. An empty list indicates all attributes
        step.filteringattributes = "";
        //GUID of the system user account that the plug-in is to execute under.
        //step.ImpersonatingUserId = "";
        step.configuration = Config.SqlConnectionString;
        try
            return crmService.Create(step);
        catch (Exception ex)
            throw new Exception("При регистрации шага произошла ошибка: " + ex.Message);
 public static Guid GetSdkMessageFilterID(CrmService.CrmService crmService, string entityName, Guid sdkMessageID)
        QueryByAttribute query = new QueryByAttribute();
        ColumnSet cs = new ColumnSet();
        cs.Attributes = new string[] { "sdkmessagefilterid" };
        query.ColumnSet = cs;
        query.EntityName = EntityName.sdkmessagefilter.ToString();
        query.Attributes = new string[] { "primaryobjecttypecode", "sdkmessageid" };
        query.Values = new string[] { entityName.ToLower(), sdkMessageID.ToString() };
        BusinessEntityCollection bec;
        try
            bec = crmService.RetrieveMultiple(query);
            throw new Exception("При получении Guid messagefilter для EntityName = '" + entityName + "', sdkMessageID = '" + sdkMessageID + "' произошла ошибка: " + ex.Message);
        if (bec.BusinessEntities != null && bec.BusinessEntities.Length > 0)
            return ((sdkmessagefilter)bec.BusinessEntities[0]).sdkmessagefilterid.Value;
        else
            return Guid.Empty;
    public static Guid GetSdkMessageID(CrmService.CrmService crmService, string messageName)
        cs.Attributes = new string[] { "sdkmessageid" };
        query.EntityName = EntityName.sdkmessage.ToString();
        query.Attributes = new string[] { "name" };
        query.Values = new string[] { messageName };
        try
            throw new Exception("При получении Guid message '" + messageName + "' произошла ошибка: " + ex.Message);
            return ((sdkmessage)bec.BusinessEntities[0]).sdkmessageid.Value;
        else
            return Guid.Empty;
Строка сервисного контракта: работает ли ограничение по срокам действия? Lazarus Dynamics CRM: Функционал 1 10.04.2009 08:04
Ограничение в 218 символов на путь xls sergeyjb Dynamics CRM: Администрирование 2 10.10.2008 10:38
Ограничение на 10 пользователей zhenek Dynamics CRM: Администрирование 3 18.09.2007 12:02
Ограничение доступа amg Dynamics CRM: Функционал 0 21.11.2006 10:40
Часовой пояс GMT +3, время: 02:34.
