Талантливый разгвоздяй
Судя по логам, АОС испытывает некоторые затруднения при общении с СУБД:
Warning: Setup could not connect the Application Object Server (AOS) instance to the database because it could not add the AOS account MSHOME\PONB$ to the database server as a login account. Installation of the AOS instance was completed, but the AOS instance cannot run without a connection to the database. You might not have permission to modify security on the database server. A database administrator can grant permission manually, and then AOS setup will be complete. For more information, see the installation log file for the error message returned by the database.
An error occurred during setup of Application Object Server (AOS).
Reason: Windows NT user or group 'MSHOME\PONB$' not found. Check the name again. |
Теги |
installation, домен, инсталляция, локально, полезное, установка, ax2009, ax4.0 |
