Чайный пьяница
Код: if (crmForm.all.customerid.DataValue != null && crmForm.all.customerid.DataValue[0] != null) { //вытаскивание телефона, запись в необходимое поле }
Не помогло,
ошибка "Требуется объект" |
Чайный пьяница
Код приведите. Я, к сожалению, не телепат.
Код следующий:
var lookupItem = new Array; lookupItem = crmForm.all.customerid.DataValue; var accountid = "lookupItem[0].id"; var authenticationHeader = GenerateAuthenticationHeader(); // Prepare the SOAP message. var xml = "<?xml version='1.0' encoding='utf-8'?>"+ "<soap:Envelope xmlns:soap='http://schemas.xmlsoap.org/soap/envelope/'"+ " xmlns:xsi='http://www.w3.org/2001/XMLSchema-instance'"+ " xmlns:xsd='http://www.w3.org/2001/XMLSchema'>"+ authenticationHeader+ "<soap:Body>"+ "<Retrieve xmlns='http://schemas.microsoft.com/crm/2007/WebServices'>"+ "<entityName>account</entityName>"+ "<id>"+lookupItem[0].id+"</id>"+ "<columnSet xmlns:q1='http://schemas.microsoft.com/crm/2006/Query' xsi:type='q1:ColumnSet'>"+ "<q1:Attributes>"+ "<q1:Attribute>telephone1</q1:Attribute>"+ "</q1:Attributes>"+ "<q1:Attributes>"+ "<q1:Attribute>name</q1:Attribute>"+ "</q1:Attributes>"+ "<q1:Attributes>"+ "<q1:Attribute>address1_line1</q1:Attribute>"+ "</q1:Attributes>"+ "<q1:Attributes>"+ "<q1:Attribute>address1_city</q1:Attribute>"+ "</q1:Attributes>"+ "<q1:Attributes>"+ "<q1:Attribute>revenue</q1:Attribute>"+ "</q1:Attributes>"+ "<q1:Attributes>"+ "<q1:Attribute>numberofemployees</q1:Attribute>"+ "</q1:Attributes>"+ "<q1:Attributes>"+ "<q1:Attribute>industrycode</q1:Attribute>"+ "</q1:Attributes>"+ "</columnSet>"+ "</Retrieve>"+ "</soap:Body>"+ "</soap:Envelope>"; // Prepare the xmlHttpObject and send the request. var xHReq = new ActiveXObject("Msxml2.XMLHTTP"); xHReq.Open("POST", "/mscrmservices/2007/CrmService.asmx", false); xHReq.setRequestHeader("SOAPAction","http://schemas.microsoft.com/crm/2007/WebServices/Retrieve"); xHReq.setRequestHeader("Content-Type", "text/xml; charset=utf-8"); xHReq.setRequestHeader("Content-Length", xml.length); xHReq.send(xml); // Capture the result. var resultXml = xHReq.responseXML; // Check for errors. var errorCount = resultXml.selectNodes('//error').length; if (errorCount != 0) { var msg = resultXml.selectSingleNode('//description').nodeTypedValue; alert(msg); } // Display the retrieved value. else { if (crmForm.all.customerid.DataValue != null && crmForm.all.customerid.DataValue[0] != null) { resultXml.selectSingleNode("//q1:telephone1").nodeTypedValue; resultXml.selectSingleNode("//q1:name").nodeTypedValue; resultXml.selectSingleNode("//q1:address1_line1").nodeTypedValue; resultXml.selectSingleNode("//q1:address1_city").nodeTypedValue; resultXml.selectSingleNode("//q1:revenue").nodeTypedValue resultXml.selectSingleNode("//q1:numberofemployees").nodeTypedValue; resultXml.selectSingleNode("//q1:industrycode").nodeTypedValue; crmForm.all.telephone1.DataValue = resultXml.selectSingleNode("//q1:telephone1").nodeTypedValue; crmForm.all.companyname.DataValue = resultXml.selectSingleNode("//q1:name").nodeTypedValue; crmForm.all.address1_line1.DataValue = resultXml.selectSingleNode("//q1:address1_line1").nodeTypedValue; crmForm.all.address1_city.DataValue = resultXml.selectSingleNode("//q1:address1_city").nodeTypedValue; crmForm.all.revenue.DataValue = resultXml.selectSingleNode("//q1:revenue").nodeTypedValue; crmForm.all.numberofemployees.DataValue = resultXml.selectSingleNode("//q1:numberofemployees").nodeTypedValue; crmForm.all.industrycode.DataValue = resultXml.selectSingleNode("//q1:industrycode").nodeTypedValue; } } |
Чайный пьяница
![]() Цитата:
Сообщение от Murzin Andrey
![]() Код следующий:
var lookupItem = new Array; lookupItem = crmForm.all.customerid.DataValue; var accountid = lookupItem[0].id; var authenticationHeader = GenerateAuthenticationHeader(); // Prepare the SOAP message. var xml = "<?xml version='1.0' encoding='utf-8'?>"+ "<soap:Envelope xmlns:soap='http://schemas.xmlsoap.org/soap/envelope/'"+ " xmlns:xsi='http://www.w3.org/2001/XMLSchema-instance'"+ " xmlns:xsd='http://www.w3.org/2001/XMLSchema'>"+ authenticationHeader+ "<soap:Body>"+ "<Retrieve xmlns='http://schemas.microsoft.com/crm/2007/WebServices'>"+ "<entityName>account</entityName>"+ "<id>"+lookupItem[0].id+"</id>"+ "<columnSet xmlns:q1='http://schemas.microsoft.com/crm/2006/Query' xsi:type='q1:ColumnSet'>"+ "<q1:Attributes>"+ "<q1:Attribute>telephone1</q1:Attribute>"+ "</q1:Attributes>"+ "<q1:Attributes>"+ "<q1:Attribute>name</q1:Attribute>"+ "</q1:Attributes>"+ "<q1:Attributes>"+ "<q1:Attribute>address1_line1</q1:Attribute>"+ "</q1:Attributes>"+ "<q1:Attributes>"+ "<q1:Attribute>address1_city</q1:Attribute>"+ "</q1:Attributes>"+ "<q1:Attributes>"+ "<q1:Attribute>revenue</q1:Attribute>"+ "</q1:Attributes>"+ "<q1:Attributes>"+ "<q1:Attribute>numberofemployees</q1:Attribute>"+ "</q1:Attributes>"+ "<q1:Attributes>"+ "<q1:Attribute>industrycode</q1:Attribute>"+ "</q1:Attributes>"+ "</columnSet>"+ "</Retrieve>"+ "</soap:Body>"+ "</soap:Envelope>"; // Prepare the xmlHttpObject and send the request. var xHReq = new ActiveXObject("Msxml2.XMLHTTP"); xHReq.Open("POST", "/mscrmservices/2007/CrmService.asmx", false); xHReq.setRequestHeader("SOAPAction","http://schemas.microsoft.com/crm/2007/WebServices/Retrieve"); xHReq.setRequestHeader("Content-Type", "text/xml; charset=utf-8"); xHReq.setRequestHeader("Content-Length", xml.length); xHReq.send(xml); // Capture the result. var resultXml = xHReq.responseXML; // Check for errors. var errorCount = resultXml.selectNodes('//error').length; if (errorCount != 0) { var msg = resultXml.selectSingleNode('//description').nodeTypedValue; alert(msg); } // Display the retrieved value. else { if (crmForm.all.customerid.DataValue != null && crmForm.all.customerid.DataValue[0] != null) { resultXml.selectSingleNode("//q1:telephone1").nodeTypedValue; resultXml.selectSingleNode("//q1:name").nodeTypedValue; resultXml.selectSingleNode("//q1:address1_line1").nodeTypedValue; resultXml.selectSingleNode("//q1:address1_city").nodeTypedValue; resultXml.selectSingleNode("//q1:revenue").nodeTypedValue resultXml.selectSingleNode("//q1:numberofemployees").nodeTypedValue; resultXml.selectSingleNode("//q1:industrycode").nodeTypedValue; crmForm.all.telephone1.DataValue = resultXml.selectSingleNode("//q1:telephone1").nodeTypedValue; crmForm.all.companyname.DataValue = resultXml.selectSingleNode("//q1:name").nodeTypedValue; crmForm.all.address1_line1.DataValue = resultXml.selectSingleNode("//q1:address1_line1").nodeTypedValue; crmForm.all.address1_city.DataValue = resultXml.selectSingleNode("//q1:address1_city").nodeTypedValue; crmForm.all.revenue.DataValue = resultXml.selectSingleNode("//q1:revenue").nodeTypedValue; crmForm.all.numberofemployees.DataValue = resultXml.selectSingleNode("//q1:numberofemployees").nodeTypedValue; crmForm.all.industrycode.DataValue = resultXml.selectSingleNode("//q1:industrycode").nodeTypedValue; } } Код: if (crmForm.all.customerid.DataValue != null && crmForm.all.customerid.DataValue[0] != null) { var lookupItem = new Array; lookupItem = crmForm.all.customerid.DataValue; var accountid = lookupItem[0].id; var authenticationHeader = GenerateAuthenticationHeader(); // Prepare the SOAP message. var xml = "<?xml version='1.0' encoding='utf-8'?>"+ "<soap:Envelope xmlns:soap='http://schemas.xmlsoap.org/soap/envelope/'"+ " xmlns:xsi='http://www.w3.org/2001/XMLSchema-instance'"+ " xmlns:xsd='http://www.w3.org/2001/XMLSchema'>"+ authenticationHeader+ "<soap:Body>"+ "<Retrieve xmlns='http://schemas.microsoft.com/crm/2007/WebServices'>"+ "<entityName>account</entityName>"+ "<id>"+lookupItem[0].id+"</id>"+ "<columnSet xmlns:q1='http://schemas.microsoft.com/crm/2006/Query' xsi:type='q1:ColumnSet'>"+ "<q1:Attributes>"+ "<q1:Attribute>telephone1</q1:Attribute>"+ "</q1:Attributes>"+ "<q1:Attributes>"+ "<q1:Attribute>name</q1:Attribute>"+ "</q1:Attributes>"+ "<q1:Attributes>"+ "<q1:Attribute>address1_line1</q1:Attribute>"+ "</q1:Attributes>"+ "<q1:Attributes>"+ "<q1:Attribute>address1_city</q1:Attribute>"+ "</q1:Attributes>"+ "<q1:Attributes>"+ "<q1:Attribute>revenue</q1:Attribute>"+ "</q1:Attributes>"+ "<q1:Attributes>"+ "<q1:Attribute>numberofemployees</q1:Attribute>"+ "</q1:Attributes>"+ "<q1:Attributes>"+ "<q1:Attribute>industrycode</q1:Attribute>"+ "</q1:Attributes>"+ "</columnSet>"+ "</Retrieve>"+ "</soap:Body>"+ "</soap:Envelope>"; // Prepare the xmlHttpObject and send the request. var xHReq = new ActiveXObject("Msxml2.XMLHTTP"); xHReq.Open("POST", "/mscrmservices/2007/CrmService.asmx", false); xHReq.setRequestHeader("SOAPAction","http://schemas.microsoft.com/crm/2007/WebServices/Retrieve"); xHReq.setRequestHeader("Content-Type", "text/xml; charset=utf-8"); xHReq.setRequestHeader("Content-Length", xml.length); xHReq.send(xml); // Capture the result. var resultXml = xHReq.responseXML; // Check for errors. var errorCount = resultXml.selectNodes('//error').length; if (errorCount != 0) { var msg = resultXml.selectSingleNode('//description').nodeTypedValue; alert(msg); } // Display the retrieved value. else { crmForm.all.telephone1.DataValue = resultXml.selectSingleNode("//q1:telephone1") == null ? "" : resultXml.selectSingleNode("//q1:telephone1").nodeTypedValue; crmForm.all.companyname.DataValue = resultXml.selectSingleNode("//q1:name") == null ? "" : resultXml.selectSingleNode("//q1:name").nodeTypedValue; crmForm.all.address1_line1.DataValue = resultXml.selectSingleNode("//q1:address1_line1") == null ? "" : resultXml.selectSingleNode("//q1:address1_line1").nodeTypedValue; crmForm.all.address1_city.DataValue = resultXml.selectSingleNode("//q1:address1_city") = null ? "" : resultXml.selectSingleNode("//q1:address1_city").nodeTypedValue; crmForm.all.revenue.DataValue = resultXml.selectSingleNode("//q1:revenue") == null ? "" : resultXml.selectSingleNode("//q1:revenue").nodeTypedValue; crmForm.all.numberofemployees.DataValue = resultXml.selectSingleNode("//q1:numberofemployees") == null ? "" : resultXml.selectSingleNode("//q1:numberofemployees").nodeTypedValue; crmForm.all.industrycode.DataValue = resultXml.selectSingleNode("//q1:industrycode") == null ? "" : resultXml.selectSingleNode("//q1:industrycode").nodeTypedValue; } }
#6 |
Так тоже не работает.
Пробую каждое поле проверять, тоже не работает: Цитата:
var errorCount = resultXml.selectNodes('//error').length; if (errorCount != 0) { var msg = resultXml.selectSingleNode('//description').nodeTypedValue; alert(msg); } // Display the retrieved value. else { if (resultXml.selectSingleNode("//q1:telephone1").nodeTypedValue != null) { alert(resultXml.selectSingleNode("//q1:telephone1").nodeTypedValue); crmForm.all.telephone1.DataValue = resultXml.selectSingleNode("//q1:telephone1").nodeTypedValue; } if (resultXml.selectSingleNode("//q1:name").nodeTypedValue != null) { alert(resultXml.selectSingleNode("//q1:name").nodeTypedValue); crmForm.all.companyname.DataValue = resultXml.selectSingleNode("//q1:name").nodeTypedValue; } if (resultXml.selectSingleNode("//q1:address1_line1").nodeTypedValue != null) { alert(resultXml.selectSingleNode("//q1:address1_line1").nodeTypedValue); crmForm.all.address1_line1.DataValue = resultXml.selectSingleNode("//q1:address1_line1").nodeTypedValue; } if (resultXml.selectSingleNode("//q1:address1_city").nodeTypedValue != null) { alert(resultXml.selectSingleNode("//q1:address1_city").nodeTypedValue); crmForm.all.address1_city.DataValue = resultXml.selectSingleNode("//q1:address1_city").nodeTypedValue; } if (resultXml.selectSingleNode("//q1:address1_stateorprovince").nodeTypedValue != null) { alert(resultXml.selectSingleNode("//q1:address1_stateorprovince").nodeTypedValue); crmForm.all.address1_stateorprovince.DataValue = resultXml.selectSingleNode("//q1:address1_stateorprovince").nodeTypedValue; } if (resultXml.selectSingleNode("//q1:address1_postalcode").nodeTypedValue != null) { alert(resultXml.selectSingleNode("//q1:address1_postalcode").nodeTypedValue); crmForm.all.address1_postalcode.DataValue = resultXml.selectSingleNode("//q1:address1_postalcode").nodeTypedValue; } if (resultXml.selectSingleNode("//q1:address1_country").nodeTypedValue != null) { alert(resultXml.selectSingleNode("//q1:address1_country").nodeTypedValue); crmForm.all.address1_country.DataValue = resultXml.selectSingleNode("//q1:address1_country").nodeTypedValue; } if (resultXml.selectSingleNode("//q1:revenue").nodeTypedValue != null) { alert(resultXml.selectSingleNode("//q1:revenue").nodeTypedValue); crmForm.all.revenue.DataValue = resultXml.selectSingleNode("//q1:revenue").nodeTypedValue; } if (resultXml.selectSingleNode("//q1:numberofemployees").nodeTypedValue != null) { alert(resultXml.selectSingleNode("//q1:numberofemployees").nodeTypedValue); crmForm.all.numberofemployees.DataValue = resultXml.selectSingleNode("//q1:numberofemployees").nodeTypedValue; } } |
#7 |
Чайный пьяница
Можно. Цепляйтесь дебагером и отлаживайте.
