Старый 20.08.2009, 14:16   #15
slivka_83 is offline
slivka_83
Консультант-джедай
Аватар для slivka_83
1,683 / 374 (16) ++++++
Попробуйте это
var authenticationHeader = GenerateAuthenticationHeader();
// Prepare the SOAP message.
var xml = "<?xml version='1.0' encoding='utf-8'?>"+
"<soap:Envelope xmlns:soap='http://schemas.xmlsoap.org/soap/envelope/'"+
" xmlns:xsi='http://www.w3.org/2001/XMLSchema-instance'"+
" xmlns:xsd='http://www.w3.org/2001/XMLSchema'>"+
authenticationHeader+
"<soap:Body>"+
"<Fetch xmlns='http://schemas.microsoft.com/crm/2007/WebServices'>"+
"<fetchXml>&lt;fetch mapping='logical'&gt;&lt;entity name='equipment'&gt;&lt;no-attrs/&gt;&lt;/entity&gt;&lt;/fetch&gt;</fetchXml>"+
"</Fetch>"+
"</soap:Body>"+
"</soap:Envelope>";
// Prepare the xmlHttpObject and send the request.
var xHReq = new ActiveXObject("Msxml2.XMLHTTP");
xHReq.Open(
"POST", "/mscrmservices/2007/CrmService.asmx", false);
xHReq.setRequestHeader(
"SOAPAction","http://schemas.microsoft.com/crm/2007/WebServices/Fetch");
"Content-Type", "text/xml; charset=utf-8");
"Content-Length", xml.length);
xHReq.send(xml);
// Capture the result.
var resultXml = xHReq.responseXML;
// Check for errors.
var errorCount = resultXml.selectNodes('//error').length;
if (errorCount != 0)
var msg = resultXml.selectSingleNode('//description').nodeTypedValue;
alert(msg);
// Process and display the results.
else
// Capture the result and UnEncode it.
var resultSet = new String();
resultSet = resultXml.text;
resultSet.replace(
'&lt;','<');
resultSet.replace(
'&gt;','>');
// Create an XML document that you can parse.
var oXmlDoc = new ActiveXObject("Microsoft.XMLDOM");
oXmlDoc.async =
false;
// Load the XML document that has the UnEncoded results.
oXmlDoc.loadXML(resultSet);
// Display the results.
var results = oXmlDoc.getElementsByTagName('result');
var msg = "\Account Id\t\t\t\tAccount Name\r";
msg +=
"--------------------------------------------------------------------------------\r";
for (i=0;i < results.length;i++)
var idValue = results[i].selectSingleNode('./equipmentid').nodeTypedValue;
msg += idValue +
"\t";
alert(msg);
Экстремал и буду экстремать!
Блога
связанные сущности
Как создать экземпляр кастомной сущности через SOAP? Tony Green Dynamics CRM: Разработка 7 27.02.2009 08:37
Получение свойств сущности DinDim Dynamics CRM: Разработка 3 06.02.2009 18:58
а можно к форме прикрутить Grid? if_maks Dynamics CRM: Разработка 4 03.01.2009 19:01
Автоматический апдейт сущности Maxoon Dynamics CRM: Функционал 7 28.05.2008 14:01
Можно ли завести CRM на локальном компе как Axapta или Navision ShadowFromXZone Dynamics CRM: Администрирование 6 16.06.2006 18:28
Часовой пояс GMT +3, время: 10:29.
