04.09.2009, 12:36 | #1 |
I don't use child table, because I have more ListViews with different data. Example, I select 3 rows from ListView 1, and example 1 row from ListView2. And than I get in table following:
X++: id Field 1.....................Field2 1 ListView1<field> 2 ListView1<field> 3 ListView1<field> 4..................................ListView2<field> Maybe are different way to solve this? Последний раз редактировалось Kent; 04.09.2009 в 12:38. |
04.09.2009, 12:52 | #2 |
May be convert your container to string with using function Global::con2str? And then use display method for showing result string in grid. Before showing result string can be arranged with some additional chars, just like LF, CR etc.
