15.09.2009, 13:22 | #1 |
ClassFactory.createViewer
How can I get "args" in ClassFactory createViewer method? I need to known which table and record call report.
15.09.2009, 13:52 | #2 |
Боец
This method is called from the run() method of the SysReportRun class (in the super() method).
\Classes\SysReportRun\run Staying at SysReportRun you can always get an original reportRun instance or its calling parameters. Good luck! |
15.09.2009, 14:02 | #3 |
I need get caller in this method. By different callers I should call different ReportOutputUserType
