Я ж привел работающий код, который меняет ориентацию в fetch'е. вот весь код метода X++: boolean fetch() { real checkedHeight, numOfLines; boolean firstRow; mapIterator mapIterator = new mapIterator(chi_invFormatMap); CHI_InvoiceFormat invoiceFormat; DictEnum dictEnum = new DictEnum(EnumNum(chi_invoiceFormat)); PrintJobSettings chi_printJobSettings; boolean pr; // Признак наличия услуг container conPrintJobSettings; #define.designStandard("Standard") ; firstIteration = true; chi_printJobSettings = new PrintJobSettings(SalesFormLetter::getPrinterSettingsFormletter(DocumentStatus::Invoice)); while (mapIterator.more()) { invoiceFormat = mapIterator.key(); if (invoiceFormat == CHI_Invoiceformat::LabelParcel) chi_printJobSettings.copies(1); else chi_printJobSettings.copies(2); if (firstIteration == false) element.reset(); if (invoiceFormat == CHI_InvoiceFormat::InvoiceFacture || invoiceFormat == CHI_InvoiceFormat::Torg12Akt) { element.design(#designStandard); } else { element.design(DictEnum.index2Symbol(invoiceFormat)); } if (mapIterator.value() != conNull()) conPrintJobSettings = mapIterator.value(); else conPrintJobSettings = chi_printJobSettings.packPrintJobSettings(); element.printJobSettings(conPrintJobSettings); TmpSalesPurchReportTable_RU_1 = headerData; firstRow = false; while select headerData { this.send(headerData); pr = false; converter = new RNumDateInWordConverter(headerData.LanguageId); element.design().languageID(headerData.LanguageId); // while (salesPurchReport.preSendReportHeader(headerData.RecId, headerData.LanguageId)) { if (firstRow) element.newPage(); firstRow = true; if (invoiceFormat == chi_invoiceFormat::Facture) this.chi_printFacture(); if (invoiceFormat == chi_invoiceFormat::Check) this.chi_printCheck(); if (invoiceFormat == chi_invoiceFormat::LabelParcel) this.chi_printLabelParcel(); if (invoiceFormat == chi_invoiceFormat::Akt) this.chi_printAkt(); if (invoiceFormat == chi_invoiceFormat::Torg12Akt || invoiceFormat == chi_invoiceFormat::Standard || invoiceFormat == chi_invoiceFormat::InvoiceFacture) { this.initSections(); this.clearTotalsOnPage(); startPageNo = element.page(); if (invoiceFormat == chi_invoiceFormat::Torg12Akt) this.chi_removeTotalsFromHeader(); numOfLines = headerData.LineNum; element.execute(3); // PageHeader element.execute(1); // Logo element.execute(7); // Body header while select dynamicData order by LineNum where dynamicData.InternalId == headerData.InternalId { if (invoiceFormat == chi_invoiceFormat::Torg12Akt && dynamicData.CHI_ItemIsService == NoYes::Yes) { pr = true; continue; } this.prepareDynamicSection(); if (dynamicData.LineNum < numOfLines || dynamicData.LineNum == 1) { checkedHeight = sectionBody.heightValue() + sectionFooter.heightValue() + sectionPageHeader.heightValue(); } else { checkedHeight = sectionBody.heightValue() + sectionFooter.heightValue() + sectionTotal.heightValue() + sectionPageHeader.heightValue() + sectionEpilog.heightValue(); } if ((pageHeight - this.currentYmm100()/100) < checkedHeight) { element.execute(14);// Footer element.newPage(); element.execute(3); // PageHeader element.execute(7); // SectionHeader this.clearTotalsOnPage(); } this.send(dynamicData); } this.send(headerData); //ivas bugfix element.execute(13);// Total element.execute(2); // Epilog salesPurchReport.postSendReportHeader(); if (invoiceFormat == chi_invoiceFormat::Torg12Akt && pr == true) { element.design("Akt"); element.design("Akt").unpackPrintJobSettings(conPrintJobSettings); element.newPage(); this.chi_printAkt(); element.design(#designStandard); } if (invoiceFormat == chi_invoiceFormat::InvoiceFacture) { element.design("Facture"); element.design("Facture").unpackPrintJobSettings(conPrintJobSettings); element.design("Facture").orientation(2); element.newPage(); this.chi_printFacture(); element.design(#designStandard); } } } firstIteration = false; } mapIterator.next(); } return true; }
aLL woRk aNd nO JoY MAKes jAck a dULL Boy |
данный код меняет ориентацию как на экране так и при печати?
А можете, если у вас есть время, сделать небольшой отчётик и выложить проектом сюда?
![]() В глухомани, в лесу Несмотря на красу Дни проводит Лиса Патрикевна. Я никак не пойму Отчего, почему Не пускают куму На деревню |
Да, меняет. Одновременно может печататься накладная Торг12 и Акт, а они с разной ориентацией
#4 |
действительно, если в рамках одного отчета менять дизайн то при печати ориентация не меняется, проглядел в коде reset() ![]() если использовать element.reset(), то получается 2 отчета с разной ориентацией, может устроит такой вариант. X++: public boolean fetch() { ; //ReportDesign1 element.execute(1); //ReportDesign2 element.reset(); element.design("ReportDesign2"); element.design("ReportDesign2").orientation(2); element.execute(1); return true; }
Теги |
orientation, paperorientation, отчет |
