#5 |
Procedure - Reference a New Assembly in the AOT Use the following procedure to reference a new assembly in the AOT: 1. Right-click AOT > References. 2. Select Add Reference. 3. The Add Reference form appears. 4. The Add reference form contains all the assemblies that have been registered in the Global Assembly Cache (GAC). However, you are not restricted to just these assemblies. Click the Browse… button to select an assembly from another location. |
За это сообщение автора поблагодарили: Zabr (4). |
Теги |
.net, ax2009, ax4.0, com-объект, excel, импорт данных, импорт файла |
