Старый 27.04.2010, 12:37   #3
anykey is offline
anykey
Сообщение от dynamax Посмотреть сообщение
Пробежался по "How to write Data Upgrade Scripts", но ясного ответа не нашёл.
В самом начале этого документа сказано когда не нужно и нужно писать скрипты:
The following changes can be made without an upgrade script:
1. Change the name of a field
2. Change the name of a table
3. Add a field to a table with a default value for every field
4. Add/change relations
5. Add/change non-unique indexes
6. Add/change delete actions
7. Add/change/delete temporary table
The following changes require an upgrade script:
1. Delete a table and save data
2. Delete a field and save data
3. Add/change unique indexes
4. Change a non-unique index into a unique index
5. Restructure where data is stored. For example, moving data from one field to another
6. Correct old data inconsistencies
7. Populate new tables with existing data
8. Populate new fields with existing data or a default value that is different from the default value for the data type
AX UK: Microsoft Dynamics AX 3.0 to 2009 Data and Code Upgrade Training Blog bot DAX Blogs 1 03.02.2009 11:15
DynamicsAxSCM: Quality Management in Dynamics AX 2009 - Upgrade essentials Blog bot DAX Blogs 0 16.12.2008 14:05
Arijit Basu: Optimizing Data Upgrade for Microsoft Dynamics AX 4.0 and 4.0 Service Pack on Microsoft SQL Server Blog bot DAX Blogs 1 10.01.2008 12:06
casperkamal: Upgrade scripts - Help Documentation for Microsoft Dynamics 4.0 & 4.0 SP1 Blog bot DAX Blogs 0 29.05.2007 21:21
Часовой пояс GMT +3, время: 00:18.
