Старый 15.10.2010, 12:54   #1
Vadik is offline
Vadik
Аватар для Vadik
3,631 / 1853 (69) ++++++++
Intelligent Data Management Framework for Microsoft Dynamics AX: Installation and Administration Guides
Brief Description
These documents describe the system requirements and the steps to install, administer, and use the Intelligent Data Management Framework for Microsoft Dynamics AX
Microsoft download center
-ТСЯ или -ТЬСЯ ?
За это сообщение автора поблагодарили: gl00mie (1).
Старый 01.11.2010, 10:18   #2
Poleax is offline
Poleax
Аватар для Poleax
1,353 / 595 (22) +++++++
Записей в блоге: 34
partnersource: Intelligent Data Management Framework For Microsoft Dynamics AX
Overview
The Intelligent Data Management Framework for Microsoft Dynamics® AX helps administrators optimize Dynamics AX database layout by providing functionality to manage key database layout techniques, by way of intuitive Archiving and Purging capabilities. The framework provides the platform for reduction in database size by purging and archiving of transactions records from sets of relating entities, while maintaining the consistency and integrity of production data. The Intelligent Data Management Framework provides customers and partners the ability to identify and discover related entities based on the Microsoft Dynamics AX metadata and to determine the purging or archiving criteria for tables. The Intelligent Data Management Framework also analyzes the Production database to determine usage patterns and assesses the health of the Microsoft Dynamics AX Application. This Framework is compatible with all supported versions of Dynamics AX. The Intelligent Datat Management Framework for Microsoft Dynamics AX is a benefit of staying enrolled in a Business Ready Enhancement plan.
Downloads
AXDataManagementFrameworkSetup_x64.msi MSI (15622 KB)
This file installs Intelligent Data Management Framework for Microsoft Dynamics AX on a 64 bit operating system.
AXDataManagementFrameworkSetup_x86.msi MSI (15645 KB)
This file installs Intelligent Data Management Framework for Microsoft Dynamics AX on a 32 bit operating system.
Administration Guide PDF (2 MB)
This document describes the administration and use of the Intelligent Data Management Framework for Microsoft Dynamics AX. Final Release (October 2010)
Installation Guide PDF (514 KB)
This document describes the system requirements and steps to install the Intelligent Data Management Framework for Microsoft Dynamics AX. Final Release (October 2010)
За это сообщение автора поблагодарили: MikeR (1), kornix (1).
Старый 01.11.2010, 10:42   #3
kornix is offline
kornix
414 / 146 (5) +++++
Вроде как выход IMDF планировали на середину этого года...
Ее основные функции, как и заявлялось: мониторинг и бекапирование базы Dynamics? Кто-нибудь уже ставил себе?
Старый 01.11.2010, 11:43   #4
Ivanhoe is offline
Ivanhoe
Аватар для Ivanhoe
4,143 / 2161 (81) +++++++++
Уже давно пытались Arijit Basu: Intelligent Data Management Framework for Microsoft Dynamics AX
Вот прямо сейчас смотрю виртуальную машину с демонстрациями AX от MS, думал что хоть там увижу эту систему. И уже не удивляюсь, что "из коробки" демонстрация не работает, нужно еще что-то доустанавливать
Ivanhoe as is..
Старый 01.11.2010, 12:44   #5
kornix is offline
kornix
414 / 146 (5) +++++
http://www.microsoft.com/downloads/e...displaylang=en
1. Запустил установку AXDataManagementFrameworkSetup_x86.msi, увидел сообщение:
2. Скачал MSChart (во вложении), запустил установку, увидел следующее:
3. Скачал RemoteDebugger для Visual Studio 2008 sp1 (здесь)
4. Повторил пункт 2 - не заработало, пришлось перезагрузиться, попробовал снова выполнить п.2 - не убирается зависимость.
Решилось!!! Чтобы зависимость убралась - нужно остановить сервис VisualStudioRemote Debugger.
5. Скачал MSDTC, установил.
6. Повторил пункт 1 - все установилось. ух..
Тип файла: rar MSChart.rar (1.75 Мб, 97 просмотров)
Последний раз редактировалось kornix; 01.11.2010 в 12:55.
За это сообщение автора поблагодарили: GBH (1).
Старый 01.11.2010, 13:06   #6
Ivanhoe is offline
Ivanhoe
Аватар для Ivanhoe
Как раз в установке то проблем нет. Вы попробуйте выполнить регламентные процедуры и посмотреть статистику с графиками, как в демо-скриншотах.
Ivanhoe as is..
Старый 01.11.2010, 13:52   #7
MikeR is offline
MikeR
MCT
Аватар для MikeR
1,628 / 627 (24) +++++++
Коллеги, а ссылочки не обновите, а то не качается ни AXDataManagementFrameworkSetup_x86.msi ни
AXDataManagementFrameworkSetup_x64.msi.
Axapta book for developer
Старый 01.11.2010, 13:59   #8
kornix is offline
kornix
414 / 146 (5) +++++
Сообщение от MikeR Посмотреть сообщение
я качал тут: https://mbs2.microsoft.com/fileexcha...f-5637e14d4edd
P.S. У меня из Google Chrome закачка не пошла, открыл эту же ссылку Internet Explorer'ом - открылось окно "Transfer"
За это сообщение автора поблагодарили: MikeR (1).
Старый 02.11.2010, 17:42   #9
MikeR is offline
MikeR
MCT
Аватар для MikeR
у меня на winServ08R2 64 bit не проходит этап проверки на MSDTS, хотя служба запущена.
Старый 03.11.2010, 09:29   #10
MikeR is offline
MikeR
MCT
Аватар для MikeR
просто сбросилась настройка в IG
Старый 04.11.2010, 12:38   #11
kornix is offline
kornix
414 / 146 (5) +++++
у меня такого не было.. а что такое IG?
Старый 12.11.2010, 12:35   #12
MikeR is offline
MikeR
MCT
Аватар для MikeR
ig -InstallationGuid
За это сообщение автора поблагодарили: kornix (1).
ax2009, администрирование, база данных, документация, инструменты, скачать (download)
dynamics-ax: AXUG Summit next week! Blog bot DAX Blogs 0 13.10.2010 22:05
emeadaxsupport: Resolving some issues you may experience when creating an AX 2009 Role Center and Enterprise Portal Site using SharePoint Server/Foundation 2010 after installing Microsoft Dynamics AX 2009 SP1 hotfix 2278963 Blog bot DAX Blogs 1 24.09.2010 11:34
Solutions Monkey: Microsofty Dynamics AX 2009 Enterprise Portal / Role Centers - Deployment Tips-n-Tricks - 2 Blog bot DAX Blogs 0 30.09.2008 07:07
gl00mie: Dynamics AX 2009 Guides and White Papers Blog bot DAX Blogs 0 13.08.2008 20:09
JOPX: Integrating MOSS 2007 and Dynamics AX Part II - installing and configuring Dynamics AX Enterprise Portal Blog bot DAX Blogs 0 02.03.2008 06:42
Часовой пояс GMT +3, время: 23:42.
