Старый 04.03.2011, 16:04   #1
Poleax is offline
Poleax
Аватар для Poleax
1,353 / 595 (22) +++++++
Записей в блоге: 34
Post The Microsoft Dynamics AX for Retail R2 Virtual PC
  1. The Microsoft Dynamics AX for Retail R2 Virtual PC New!!!
    Partnersource Link: https://mbs.microsoft.com/partnersou...rintpage=false
    VM в архиве разбита на 28 частей. Общий размер архива ~ 19ГБ.
    The Microsoft Dynamics AX for Retail R2 Virtual PC consists of multiple downloads, listed below. Download all the components to a folder on your hard disk, then double-click the first component, AX for Retail R2 - RTM VPC.part001.exe, and follow the instructions on your screen. The files will be expanded and reassembled into their original folder structure. Demo Data and Instructions are embedded in the files.
  2. Документация и описание по Microsoft Dynamics AX for Retail R2:
    Partnersource Link: Microsoft Dynamics AX for Retail
  3. Partnersource Link: Hotfixes Released for Microsoft Dynamics AX for Retail
    • Microsoft Dynamics AX for Retail R2
      This section lists all of the hotfixes that have been released for Microsoft Dynamics AX for Retail R2. Hotfixes are numbered consecutively per component. Each hotfix is cumulative, meaning each hotfix also contains the other hotfixes that have been released for that component since the last service pack.
      Microsoft Dynamics AX for Retail R2 is compatible with the following:
      Microsoft Dynamics® AX 2009 SP1 Rollup 6 (5.0.1500.3761)
      The RTM version of Microsoft Dynamics AX for Retail R2 is 5.0.1506.656 (Retail Headquarters > Setup > Parameters > Version).
    • Microsoft Dynamics AX for Retail R1
      This section lists all of the hotfixes that have been released for Microsoft Dynamics AX for Retail R1. Hotfixes are numbered consecutively per component. Each hotfix is cumulative, meaning each hotfix also contains the other hotfixes that have been released for that component since the last service pack.
      Microsoft Dynamics AX for Retail R1 is compatible with the following:
      Microsoft Dynamics AX 2009 SP1 Rollup 4 (5.0.1500.2116)
      The RTM version of Microsoft Dynamics AX for Retail R1 is 5.0.1506.130 (Retail Headquarters > Setup > Parameters > Version).
Старый 04.03.2011, 16:29   #2
George Nordic is offline
George Nordic
Аватар для George Nordic
4,479 / 1250 (50) ++++++++
Записей в блоге: 9
Хм. Не понял. Т.е. POS - это просто рабочее место AX? Нет отдельного решения типа Microsoft Retail POS со своим сервером и последующей синхронизацией с DAX со схлопыванием проводок?
С Уважением,
Георгий
Старый 04.03.2011, 16:45   #3
Ivanhoe is offline
Ivanhoe
Аватар для Ivanhoe
4,143 / 2156 (80) +++++++++
POS - это как раз отдельное ПО для магазина. Со своим сервером и т.п. Интеграция с back-office одновременно и онлайн (поиск клиента например), так и офф-лайн - по закрытию смены.
POS можно немного расширять, разрабатывая свои dll, но это доступно только для определенных функций.
В R2 появились хоть какие-то бизнес-процессы под ритейл - пополнение магазинов, расширенная работа с номенклатурой и ценообразованием, концессия. По руководству разбираться тяжело - желательно сразу виртуалку смотреть.
Ivanhoe as is..
ax2009, retail, virtual pc, vpc
Сергей Герасимов: Что нового в Microsoft Dynamics AX 4.0 Blog bot DAX Blogs 0 16.01.2007 11:00
Часовой пояс GMT +3, время: 17:18.
