Я сделал как Вы просили, добавил права на таблицы, я так понял это нужно было добавить туда где у меня запрос SQL?
X++: Grant Select ON dbo.Salesplan TO [NT AUTHORITY\NETWORK SERVICE] GO Grant Select ON dbo.SalesplanData TO [NT AUTHORITY\NETWORK SERVICE] GO Grant Select ON dbo.Salesfact TO [NT AUTHORITY\NETWORK SERVICE] GO Grant Select ON dbo.OpportunityBase TO [NT AUTHORITY\NETWORK SERVICE] GO Grant Select ON dbo.OpportunityExtensionBase TO [NT AUTHORITY\NETWORK SERVICE] GO Grant Select ON dbo.New_trendBase TO [NT AUTHORITY\NETWORK SERVICE] GO Grant Select ON dbo.New_trendExtensionBase TO [NT AUTHORITY\NETWORK SERVICE] GO Grant Select ON dbo.New_departmentBase TO [NT AUTHORITY\NETWORK SERVICE] GO Grant Select ON dbo.New_departmentExtensionBase TO [NT AUTHORITY\NETWORK SERVICE] GO Grant Select ON dbo.SystemUserBase TO [NT AUTHORITY\NETWORK SERVICE] GO declare @unix_time_now int select @unix_time_now = DATEDIFF(s, 'Jan 1 1970',GETUTCDATE()) declare @unix_time_start2 int declare @unix_time_end2 int declare @unix_time_start int declare @unix_time_end int declare @D datetime set @D = getdate() select @unix_time_start2 = DATEDIFF(s, 'Jan 1 1970',DateAdd( Year , DateDiff(Year , 0, @D) , 0) ) select @unix_time_end2 = DATEDIFF(s, 'Jan 1 1970',DateAdd( day, -1, DateAdd( Year , DateDiff(Year , 0, @D) +1, 0)) ) select @unix_time_start = DATEDIFF(s, '01.01.1970', @aStartDate ) select @unix_time_end = DATEDIFF(s, '01.01.1970', @aEndDate ) select new_departments.New_name as Company, COALESCE( (select Sum(Salesplan.Price) from Salesplan where Salesplan.ParentSalesplanId = (select SalesplanId from Salesplan where @unix_time_now BETWEEN DateStart AND DateEnd and ParentSalesplanId is NULL) and Salesplan.CreatedBy = trend.OwningUser) , 0) as PlanCompany, new_trend.New_Department as GroupName, COALESCE ( (select Sum(Salesplan.Price) from Salesplan where Salesplan.ParentSalesplanId = (select SalesplanId from Salesplan where @unix_time_now BETWEEN DateStart AND DateEnd and ParentSalesplanId is NULL) and Salesplan.ManagerId = new_trend.New_systemuser_new_trend) , 0) as PlanGroup, Coalesce ( ( select Sum(Salesfact.Price) from Salesfact, OpportunityExtensionBase, OpportunityBase, SystemUserBase where Salesfact.DateFact BETWEEN @unix_time_start AND @unix_time_end and Salesfact.AgreementCode = OpportunityExtensionBase.New_Agreement_Code and OpportunityBase.OpportunityId = OpportunityExtensionBase.OpportunityId and ( (OpportunityBase.OwningUser = new_trend.New_systemuser_new_trend and OpportunityBase.OwningUser = SystemUserBase.SystemUserId) or (OpportunityBase.OwningUser = SystemUserBase.SystemUserId and SystemUserBase.ParentSystemUserId = new_trend.New_systemuser_new_trend) ) ) , 0) as FactGroup, new_trend.New_name as Department, COALESCE ( (select Sum(SalesplanData.Price) from SalesplanData where SalesplanData.SalesplanId = (select SalesplanId from Salesplan where @unix_time_now BETWEEN DateStart AND DateEnd and ParentSalesplanId is NULL) and SalesplanData.DepartmentId = new_trend.New_trendId and SalesplanData.Period <> 5 and SalesplanData.Period is NOT NULL and SalesplanData.ProductstypeId is NOT NULL and SalesplanData.ManagerId is NOT NULL) , 0) as PlanDepartment, Coalesce ( ( select Sum(Salesfact.Price) from Salesfact, OpportunityExtensionBase, OpportunityBase, SystemUserBase where Salesfact.DateFact BETWEEN @unix_time_start AND @unix_time_end and Salesfact.AgreementCode = OpportunityExtensionBase.New_Agreement_Code and OpportunityBase.OpportunityId = OpportunityExtensionBase.OpportunityId and ( (OpportunityBase.OwningUser = new_trend.New_systemuser_new_trend and OpportunityBase.OwningUser = SystemUserBase.SystemUserId) or (OpportunityBase.OwningUser = SystemUserBase.SystemUserId and SystemUserBase.ParentSystemUserId = new_trend.New_systemuser_new_trend) ) ) , 0) as FactDepartment, new_trend.New_trendId as DepartmentId, new_trend.New_systemuser_new_trend as GroupUserId, new_departments.New_departmentId as CompanyId, Coalesce ( (select Sum(O.EstimatedValue_Base) as Sum from OpportunityBase as O, OpportunityExtensionBase as OBase where O.OpportunityId = OBase.OpportunityId and DATEDIFF(s, '01.01.1970 00:00:00', O.ModifiedOn) BETWEEN @unix_time_start and @unix_time_end and O.CloseProbability >= 80 and O.statecode = 0 and OBase.New_blid = new_trend.New_trendId ) ,0) as OpportunityClosedSum, Coalesce ( (select Sum(O.EstimatedValue_Base) as Sum from OpportunityBase as O, OpportunityExtensionBase as OBase where O.OpportunityId = OBase.OpportunityId and DATEDIFF(s, '01.01.1970 00:00:00', O.ModifiedOn) BETWEEN @unix_time_start and @unix_time_end and O.CloseProbability < 80 and O.CloseProbability >= @aProbability and O.statecode = 0 and OBase.New_blid = new_trend.New_trendId ) ,0) as OpportunityOpenSum from New_departmentExtensionBase as new_departments left outer join New_departmentBase as departments on departments.New_departmentId = new_departments.New_departmentId and departments.statecode = 0 left outer join New_trendExtensionBase as new_trend on new_trend.New_buid = departments.New_departmentId left outer join New_trendBase as trend on new_trend.New_trendId = trend.New_trendId and trend.statecode = 0 where trend.statecode is NOT NULL and departments.statecode is NOT NULL and new_departments.New_name NOT LIKE '%СНГ%' order by new_departments.New_name, new_trend.New_Department, new_trend.New_Name ![]() ![]() ![]() Но появляются ошибки. |
Также я удалил справа DataSource1.rds в Shared Data Source
Чайный пьяница
Этот запрос надо запустить один раз, чтобы дать права на таблицы и не более.
Эмо разработчик, сначала пишу код, потом плачу над его несовершенством. Подписывайтесь на мой блог, twitter и YouTube канал. Пользуйтесь моим Ultimate Workflow Toolkit |
#4 |
а где его запустить в SQL-е? вручную???
#5 |
Запустил эти запросы
GRANT Select и т.д. ко всем используемым таблицам в запросе которые я использую в SQL Management Studio единожды. затем сохранил отчет в Visual Studio и постандартной схеме выгрузил его в CRM. та же ошибка X++: .
"dsSalesPlanFact".
