Старый 22.06.2011, 08:13   #1
Dynamics AX Sustained Engineering: Sales tax information is not recaculated if document date is changed in a journal when sales tax is calculated using document date
Источник: http://blogs.technet.com/b/dynamicsa...ment-date.aspx
Problem:
When setting the General ledger parameter for Calculation Date Type = Document date sales tax information is not refreshed on journal forms when the document date is changed. Posted values are correct, however the display in the journal is not refreshed.
Resolution:
To resolve this issue the following code changes can be made.
Change \Classes\LedgerJournalEngine\documentDateModified
    if (ledgerJournalTrans.CashDiscCode)
        this.calculateCashDisc(ledgerJournalTrans);
To:
        if (TaxParameters::find().TaxCalculationDateType == TaxCalculationDateType::DocumentDate)
        this.clearTaxAmountCache(ledgerJournalTrans);
Последний раз редактировалось Poleax; 22.06.2011 в 09:45. Причина: оформление
Dynamics AX Sustained Engineering: POS Transaction with Sales Order that nets to $0.00 posting failure in statement Blog bot DAX Blogs 0 06.01.2011 20:16
Dynamics AX Sustained Engineering: Error when opening EU Sales List form when not licensed for Project Blog bot DAX Blogs 0 25.08.2010 01:05
Часовой пояс GMT +3, время: 12:51.
