обнуление полей плагином
Добрый день, а вот такая простая задача, нужно плагином обнулить поля,
TargetRetrieveDynamic targetRetrieve = new TargetRetrieveDynamic(); targetRetrieve.EntityName = "contract"; targetRetrieve.EntityId = contractId; // Create the request object. RetrieveRequest retrieve = new RetrieveRequest(); retrieve.Target = targetRetrieve; retrieve.ColumnSet = new AllColumns(); retrieve.ReturnDynamicEntities = true; // Execute the request. RetrieveResponse retrieved = (RetrieveResponse)service.Execute(retrieve); // Extract the DynamicEntity from the request. DynamicEntity entity = (DynamicEntity)retrieved.BusinessEntity; entity.Properties.Remove("gar_state_contract"); entity.Properties.Remove("gar_contracts"); entity.Properties.Remove("title"); entity.Properties.Remove("activeon"); entity.Properties.Remove("gar_date_contract_expiry"); entity.Properties.Remove("gar_date_return_contract"); // Contact PreferredContactMethodCode property PicklistProperty picklist = new PicklistProperty(); picklist.Name = "gar_state_contract"; picklist.Value = new Picklist(); picklist.Value.Value =1 ; LookupProperty lkProp = new LookupProperty(); lkProp.Name = "gar_contracts"; lkProp.Value = new Lookup(); StringProperty strProp = new StringProperty(); strProp.Name = "title"; strProp.Value = ""; CrmDateTimeProperty dProp1 = new CrmDateTimeProperty(); dProp1.Name = "activeon"; dProp1.Value = new CrmDateTime(string.Format(System.Globalization.CultureInfo.InvariantCulture, "{0:s}", "2/24/1955")); CrmDateTimeProperty dProp2 = new CrmDateTimeProperty(); dProp2.Name = "gar_date_contract_expiry"; dProp2.Value = new CrmDateTime(string.Format(System.Globalization.CultureInfo.InvariantCulture, "{0:s}", "2/24/1955")); CrmDateTimeProperty dProp3 = new CrmDateTimeProperty(); dProp3.Name = "gar_date_return_contract"; dProp3.Value = new CrmDateTime(string.Format(System.Globalization.CultureInfo.InvariantCulture, "{0:s}", "2/24/1955")); // ArrayList arrProps = new ArrayList(); // Add properties to ArrayList. entity.Properties.Add(picklist); entity.Properties.Add(lkProp); entity.Properties.Add(strProp); entity.Properties.Add(dProp1); entity.Properties.Add(dProp2); entity.Properties.Add(dProp3); // Update the properties array on the DynamicEntity. //entity.Properties = // (Property[])arrProps.ToArray(typeof(Property)); // Create the update target. TargetUpdateDynamic updateDynamic = new TargetUpdateDynamic(); // Set the properties of the target. updateDynamic.Entity = entity; // Create the update request object. UpdateRequest update = new UpdateRequest(); // Set request properties. update.Target = updateDynamic; // Execute the request. UpdateResponse updated = (UpdateResponse)service.Execute(update);
rurik |
нужно вот этот участок кода или нет?
rurik |
или достаточно ?
rurik |
Чайный пьяница
Этого мало. Если вы убираете поле и вызываете апдейт, то с полем - ничего не происходит. Для очищения посмотрите следующее - http://a33ik.blogspot.com/2009/11/cl...-dynamics.html
Для очищения поля типа стринг - просто передайте в него пустую строку.
со стрингом я догадался а вот с остальными спасибо)
rurik |
#6 |
кстати а с контрактом и строкой контракта прйдет обнуление дат начала и окончания?
там же у них привязка есть что даты строки между датами контракта
rurik |
#7 |
Чайный пьяница
Сходу не скажу, потому что никогда такого не проверял, но написать простое консольное приложение чтобы проверить, как это работает - дело 15-20 минут.
