Старый 31.08.2012, 11:23   #7
Ponka is offline
Ponka
Хелп, кто-нибудь сталкивался с проблемой, при которой стандартные отчеты, которые есть по умолчанию работают, а если создаешь свой любой отчет даже через СРМ, то пишет
Если нажимаешь "повтор попытки", пишет "недопустимый аргумент". Еще пару раз на повтор "404 - File or directory not found."
В логе приложения:
Event code: 3005
Event message: An unhandled exception has occurred.
Event time: 8/31/2012 11:23:07 AM
Event time (UTC): 8/31/2012 7:23:07 AM
Event ID: aaf70ff1dd904e6b950c87885c201da6
Event sequence: 34172
Event occurrence: 26
Event detail code: 0
Application information:
Application domain: /LM/W3SVC/1/ROOT-1-129908158689239396
Trust level: Full
Application Virtual Path: /
Application Path: C:\Program Files\Microsoft Dynamics CRM\CRMWeb\
Machine name: WZ-CRM01
Process information:
Process ID: 3180
Process name: w3wp.exe
Account name: NT AUTHORITY\NETWORK SERVICE
Exception information:
Exception type: CrmArgumentNullException
Exception message: name
at Microsoft.Crm.ReportObjectModel.ReportServerOrganizationContext.GetItemPath(String name, Boolean isSharedReport)
at Microsoft.Crm.Web.Reporting.RemoteSrsReportViewer.LoadReportAndSetParameters()
at Microsoft.Crm.Application.Controls.AppUIPage.OnPreRender(EventArgs e)
at System.Web.UI.Control.PreRenderRecursiveInternal()
at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
Value cannot be null.
Parameter name: name
Request information:
Request URL: http://wz-crm01/test/CRMReports/rsvi...ortviewer.aspx
Request path: /test/CRMReports/rsviewer/reportviewer.aspx
User host address: 172.16.32.177
User: domen\user
Is authenticated: True
Authentication Type: NTLM
Thread account name: NT AUTHORITY\NETWORK SERVICE
Thread information:
Thread ID: 40
Is impersonating: False
Stack trace: at Microsoft.Crm.ReportObjectModel.ReportServerOrganizationContext.GetItemPath(String name, Boolean isSharedReport)
Custom event details:
Такое ощущение, что проблема в правах, но не могу понять где, репорты и стандартные же отчеты работают.
вопрос по отображению данных mistah Dynamics CRM: Функционал 6 14.11.2011 15:43
настройка отслеживания контактов outlook в срм Clever Dynamics CRM: Функционал 1 02.11.2009 22:33
перенос данных из аутлука в срм Clever Dynamics CRM: Функционал 0 27.10.2009 12:59
Восстановление веб-узлов СРМ sanych_81 Dynamics CRM: Администрирование 2 29.08.2009 12:20
Вопрос от новичка, вопрос про оповещение по электронной почте при создание любого события. echo_igor Dynamics CRM: Прочие вопросы 2 15.06.2009 11:07
Часовой пояс GMT +3, время: 08:59.
