AX2012R2 AOS падает при старте Reporting Services
Такая штука, если настроить нормально бизнес коннектор на АОС и стартовать сервис
SQL Server Reporting Services То через время (до 3 минут) падает АОС с такой вот ошибкой: The description for Event ID 180 from source Microsoft Dynamics AX cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer. If the event originated on another computer, the display information had to be saved with the event. The following information was included with the event: Microsoft Dynamics AX Business Connector Session 3. Ктони будь знает как можно поправить? |
