Старый 05.09.2013, 22:11   #1
bojensen: Setting up scheduled processing of cubes in AX2012
Источник: http://blogs.bojensen.eu/?p=4740
  Here is a quick guide on how you can easily and quickly setup scheduled processing of the cubes for Microsoft Dynamics AX 2012. The same approach works for other Analysis Databases, but sometimes it helps to put things in context in order to make it easier for you AX geeks out there. I’m assuming [...]
Старый 05.09.2013, 22:11   #2
Источник: http://blogs.bojensen.eu/?p=4742
emeadaxsupport: AX2012 Upgrades - Setting a clean AX2012 database to start with the upgrade check-list and not the Initialization check-list. Blog bot DAX Blogs 1 13.02.2013 23:47
sumitax: AX2012 – Cubes Blog bot DAX Blogs 0 30.06.2012 20:12
sumitax: AX2012 setting up VPC using virtualbox Blog bot DAX Blogs 0 18.11.2011 16:11
lcash: Processing OLAP Cubes and AX Companies Blog bot DAX Blogs 0 15.10.2009 07:06
Часовой пояс GMT +3, время: 12:46.
