Сообщение от axm2013
![]() А во всяких Global Assembly Cache регистрировали с помощью gacutil?
https://nasheet.wordpress.com/2012/0...use-dll-in-ax/ Пример из 12 ки но думаю идеи схожи Цитата:
Assembly exist in the Global Assembly Cache
Follow these steps to add a reference that exists in the Global Assembly Cache: 1. If the DLL has been added to the Global Assembly Cache, you can right-click on the Reference node in the AOT and select Add Reference. //и т.д. Assembly not in Global Assembly Cache If the file does not exist in the Global Assembly Cache follow these steps: 1. Click on the Browse button in the Add Reference form shown above and find the DLL file. // и т.д. Цитата:
Решила проблему так. В файле WebReferenceGenerator.config (путь \Program Files\Microsoft Dynamics AX\50\Server\AxDev\Bin) добавила X++: <compilation> <assemblies> <!-- These assemblies are used as references for compiling web service proxies. --> <add assembly="System, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" /> <add assembly="System.Xml, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" /> <add assembly="System.Data, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" /> <add assembly="System.ServiceModel, Version=3.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" /> <add assembly="System.Runtime.Serialization, Version=3.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" /> <add assembly="System.ServiceModel.Web, Version=3.5.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35" /> <add assembly="System.Printing, Version=3.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35" /> <!-- --> <add assembly="Microsoft.Dynamics.IntegrationFramework, Version=5.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35" /> </assemblies> </compilation> |
За это сообщение автора поблагодарили: (1). |
Теги |
.net, dll |
