Старый 11.09.2015, 14:34   #2
axm2013
Гость
n/a
Following is an example of an edit method on a form data source.
edit Amount settle(boolean set, CustTrans _CustTrans, Amount U)
https://msdn.microsoft.com/en-us/lib...or=-2147217396
emeadaxsupport: Error executing code: FormRun (data source) has no valid runable code in method 'new' when trying to edit Project workflow Blog bot DAX Blogs 0 24.06.2015 14:11
Edit method axotnik88 DAX: Программирование 0 11.10.2014 23:25
emeadaxsupport: Dynamics Ax 2012: How to implement an edit method and use it within Enterprise Portal Blog bot DAX Blogs 0 13.11.2013 22:11
TwC: Validate access to return value from display/edit method. HorrR DAX: Программирование 10 05.03.2008 12:17
Data Method с модификатором Edit simply2double DAX: Программирование 20 29.09.2004 10:36
Часовой пояс GMT +3, время: 16:52.
