Старый 02.03.2016, 22:12   #1
Infolog in batch task history using SysOperation framework
Источник: http://alexvoy.blogspot.com/2016/03/...ory-using.html
If you add tasks to a batch job using SysOperation framework, like the following:
while (mapIterator.more())
if (!batchHeader)
batchHeader = this.getCurrentBatchHeader();
controller = wblDirPartyMergeTaskController::construct();
if (batchHeader)
batchInfo = controller.batchInfo();
batchHeader.addRuntimeTask(controller, this.getCurrentBatchTask().RecId);
else
setPrefix(batchInfoStr);
controller.parmExecutionMode(SysOperationExecutionMode::Synchronous);
controller.run();
mapIterator.next();
if (batchHeader)
batchHeader.save();
You need to set Execution mode to Synchronous while initializing your service class controller.
// class wblDirPartyMergeTaskController extends SysOperationServiceController
public void new()
super();
// default for controllers in these classes is synchronous execution
// batch execution will be explicitly specified. The default for
// SysOperationServiceController is ReliableAsynchronous execution
this.parmExecutionMode(SysOperationExecutionMode::Synchronous);
this.parmOther(newValue);
Otherwise you will see nothing in bath tasks history infolog.
patrickmouwen: Dynamics AX Retail: how to automate processes and interfaces in a combined way Blog bot DAX Blogs 0 23.12.2015 23:11
Microsoft Dynamics CRM Team Blog: Creating and customizing task flows Blog bot Dynamics CRM: Blogs 0 11.12.2015 04:14
emeadaxsupport: Update to AX 2012 Framework Component Documentation: SysOperation Framework Blog bot DAX Blogs 0 09.06.2012 00:11
axinthefield: Optimizing AX Batch Performance - Batch Group Configuration Blog bot DAX Blogs 0 01.04.2011 13:11
axaptapedia: Batch processing Blog bot DAX Blogs 0 29.01.2009 17:05
Часовой пояс GMT +3, время: 23:54.
