B1.2 Create a report in NAV 2009 using the external assembly
Try to remember once again: The goal is to create a new report using the external assembly.
![]() If you like you can also insert a caption for the report and/or company name and page number etc. At this point we will move into Visual Studio
![]() Now we will setup the external assembly for using in this report.
![]() We will now change the expression of the second textbox calling the assembly For calling the assembly we have to call the Code region – function(variable) name – name of function in the assembly
![]() That’s it. Now it’s time to save, compile and start the report.
![]() Attention: If you have no output or a blank page in your preview, please check if you have a database user in your company because this example is based on database user list…(or use another table ;-) Using External Assemblies in NAV 2009 reporting Part II Using External Assemblies in NAV 2009 reporting Part I Training- NAV 2009 Reporting mit RDLC Advanced Далее
