Старый 20.02.2017, 13:05   #1
Stitch_MS is offline
Stitch_MS
Аватар для Stitch_MS
397 / 483 (17) +++++++
It is best practice to use the (SetEnumerator) class instead of the SetIterator class. This avoids problems if you are accessing the set on one tier with an iterator on another tier. Set iterators and the sets over which they iterate must be on the same client/server side. If you use SetIterator and code is marked as Called from, it is possible that the set and the iterator will end up on different tiers, and the code will fail. If you use SetEnumerator, the enumerator is automatically created on the same tier as the set. Also, to move to the next item in a set, you must explicitly call the more and next methods if you are using a set iterator. If you use SetEnumerator, you only have to call moveNext method.
https://msdn.microsoft.com/en-us/lib...titerator.aspx
Старый 20.02.2017, 13:20   #2
Vasiliusis is offline
Vasiliusis
Сообщение от Stitch_MS Посмотреть сообщение
в setEnumerator нет метода удаления. С SetIterator другая проблема
буду делать с помощью List и ListIterator, он отработал
За это сообщение автора поблагодарили: ax_mct (3).
remove, set, беда, проблема
Классы коллекций (инициализация, сериализация): List, Set, Map. petergunn DAX: База знаний и проекты 14 09.07.2025 11:37
emeadaxsupport: How to set up Images to show in MPOS Blog bot DAX Blogs 0 01.07.2015 19:11
ax_gfm_framework_team: Clear the dimension set balance ledger dimension cache Blog bot DAX Blogs 0 13.12.2013 07:12
Malaysia: Set Blog bot DAX Blogs 0 29.10.2012 19:11
fed: Net requirements update in MRP Module and Working Set of MRP Blog bot DAX Blogs 14 08.05.2012 13:09
Часовой пояс GMT +3, время: 23:42.
