Старый 14.11.2005, 13:11   #1
rkrivov is offline
rkrivov
Аватар для rkrivov
31 / 10 (1) +
Post Очередной вопрос про Query
Доброго времени суток!
У меня очередной вопрос про Query. Как можно программно создать запрос, который реализовал бы следующий код на X++ :
LedgerBalancesDimTrans lb,lbBuf;
while select lb
    group by dimension
        where
lb.AccountNum == LedgerDistribByAlg.OffsetAccountNum) ||
lb.AccountNum == LedgerDistribByAlg.BaseAccountNum)
lb.TransDate <= dateEndMth(ledgerJournalDistribTable.Period))
notexists join lbbuf
        where
lbbuf.AccountNum == LedgerDistribByAlg.OffsetAccountNum) ||
lbbuf.AccountNum == LedgerDistribByAlg.BaseAccountNum)
lbbuf.TransDate <= dateEndMth(ledgerJournalDistribTable.Period))    &&
lbbuf.Dimension[_dimensionNumber] !=lb.Dimension[_dimensionNumber] )
lbbuf.Dimension[_dimensionNumber] ==lb.Dimension[_dimensionNumber
lB.Dimension[_dimensionNumber]=='')
Я дулаю следующее:
= new Query();
fieldName =strfmt("dimension[%1]"_dimensionNumber)
fieldId fieldName2Id(tableNum(LedgerBalancesDimTrans), fieldName);
qbds_lb q.addDataSource(tableNum(LedgerBalancesDimTrans), 'A');
qbds_lb.orderMode(OrderMode::GroupBy);
qbds_lb.addSortField(fieldId);
qbr qbds_lb.addRange(fieldNum(LedgerBalancesDimTransTransDate));
qbr.value(SysQuery::range(DateNull(), dateEndMth(ledgerJournalDistribTable.Period)));
if (
qbr qbds_lb.addRange(fieldNum(LedgerBalancesDimTransAccountNum));
qbr.value(SysQuery::value(LedgerDistribByAlg.OffsetAccountNum));
if (
qbr.value(SysQuery::value(LedgerDistribByAlg.BaseAccountNum));
qbds_lbbuf qbds_lb.addDataSource(tableNum(LedgerBalancesDimTrans), 'B');
qbds_lbbuf.relationsfalse );
qbr qbds_lbbuf.addRange(fieldNum(LedgerBalancesDimTransTransDate));
if (
qbr qbds_lbbuf.addRange(fieldNum(LedgerBalancesDimTransAccountNum));
if (
qbds_lbbuf.joinMode(JoinMode::NoExistsJoin);
ds1 strfmt("%1.%2"qbds_lb.name(), fieldName);
ds2 strfmt("%1.%2"qbds_lbbuf.name(), fieldName);
queryExression strfmt("(%2 != %1) && ((%2 == %1) || (!%1))"ds1ds2 );
qbr qbds_lbbuf.addRange(fieldId);
qbr.value(queryExression);
qR = new QueryRun(q);
// qR.reset();
while (qR.next())
Но оно не работает. Выдает сообщение "Ошибка расширенного диапазона запроса: Ожидается правая круглая скобка рядом с 15"
Последний раз редактировалось rkrivov; 14.11.2005 в 13:14.
Старый 14.11.2005, 13:34   #2
sukhanchik is offline
sukhanchik
Аватар для sukhanchik
3,340 / 3558 (125) ++++++++++
Напишите вместо
queryExression = strfmt("(%2 != %1) && ((%2 == %1) || (!%1))", ds1, ds2 );
queryExression = strfmt("((%2 != %1) && ((%2 == %1) || (!%1)))", ds1, ds2 );
Старый 14.11.2005, 13:57   #3
rkrivov is offline
rkrivov
Аватар для rkrivov
31 / 10 (1) +
Такая же фигня... получил - Ошибка расширенного диапазона запроса: Ожидается правая круглая скобка рядом с 16.
Старый 14.11.2005, 14:45   #4
Ruff is offline
Ruff
Дмитрий Ерин
Аватар для Ruff
475 / 396 (14) ++++++
Хм... Честно говоря, не вникал в суть того, что Вы пытаетесь сделать, но сдается мне, что в Ваш запрос закралась какая-то бяка... Попытка оптимизировать (по правилу поглощения, кажется) условие:
привела к следующему:
"(%2 != %1) && (!%1)"
Что по сути означает "первый параметр всегда пустой, а второй - всегда непустой". Может быть это именно то, что Вам и нужно, но зачем тогда такие сложные сравнения?
Старый 14.11.2005, 17:05   #5
rkrivov is offline
rkrivov
Аватар для rkrivov
31 / 10 (1) +
Все равно не спасает... ошибка все таже
Старый 14.11.2005, 17:07   #6
Hezl is offline
Hezl
Аватар для Hezl
138 / 16 (1) ++
Попробуй все выражение взять в скобки.
Последний раз редактировалось Hezl; 14.11.2005 в 17:11.
Старый 14.11.2005, 17:12   #7
rkrivov is offline
rkrivov
Аватар для rkrivov
31 / 10 (1) +
Уже брал и не в одни... не берет
Старый 14.11.2005, 17:15   #8
AndyD is offline
AndyD
КОРУС Консалтинг
2,560 / 2480 (88) +++++++++
Скобки здесь не причем.
Разборщик Axapta'ы не понимает обращение к полям в виде массива ("A.dimension[1]"). Можно обратиться к первому полю массива просто указав его имя ("A.dimension"). К остальным достучаться не получается даже через имя поля в б/д ("dimension2_" или "dimension3_")
Axapta v.3.0 sp5 kr2
Старый 14.11.2005, 17:16   #9
rkrivov is offline
rkrivov
Аватар для rkrivov
31 / 10 (1) +
А как получить физическое имя поля (то, что в базе) по его коду или аксаптовскому имени?
Старый 14.11.2005, 17:17   #10
Hezl is offline
Hezl
Аватар для Hezl
138 / 16 (1) ++
Если я правильно помню, то подобный "расширенный" фильтр нельзя использовать для элементов массива с индексом более 1. У тебя fieldName = dimension[...]
Немного опоздал
Последний раз редактировалось Hezl; 14.11.2005 в 17:32.
Старый 14.11.2005, 17:26   #11
rkrivov is offline
rkrivov
Аватар для rkrivov
31 / 10 (1) +
вот что аксапта выдала "Ошибка расширенного диапазона запроса: B.dimension_5 не является корректной парой datasource.field рядом с 21."
Старый 14.11.2005, 17:43   #12
AndyD is offline
AndyD
КОРУС Консалтинг
Сообщение от rkrivov
DictTable.fieldName(filedid2ext(fieldnum(LedgerBalancesDimTrans, Dimension), 5),
    DBBackend::Sql);
Во-первых, поле называется dimension5_
Во-вторых, все равно не поможет
За это сообщение автора поблагодарили: Ace of Database (2).
Старый 14.11.2005, 17:48   #13
rkrivov is offline
rkrivov
Аватар для rkrivov
31 / 10 (1) +
Исчерпывающий ответ... главное поможет
Старый 14.11.2005, 17:59   #14
AndyD is offline
AndyD
КОРУС Консалтинг
Извините.
Выше я уже писал, что можно обратиться только к первому полю массива. Не совсем понял какие ко мне претензии
Старый 14.11.2005, 18:05   #15
rkrivov is offline
rkrivov
Аватар для rkrivov
31 / 10 (1) +
К вам никаких притензий... спасибо за помощь... но мне нужно обратиться ко всем аналитикам, а не только к первой
Старый 14.11.2005, 18:42   #16
rkrivov is offline
rkrivov
Аватар для rkrivov
31 / 10 (1) +
Самое интересное что при обращение к первой аналитике (т.е. к полю DIMENSION, а не к DIMENSION5_) получаем сообщение "Ошибка расширенного диапазона запроса: Ожидается правая круглая скобка рядом с 36."
Называется от чего ушли к тому и пришли
Последний раз редактировалось rkrivov; 14.11.2005 в 19:08.
Старый 15.11.2005, 11:23   #17
rkrivov is offline
rkrivov
Аватар для rkrivov
31 / 10 (1) +
Angry Ну не работает эта з(а)раза
В общем так... вот код, который формирует запрос (он несколько изменился) :
q = new Query();
qbds_lb = q.addDataSource(tableNum(LedgerBalancesDimTrans));
qbds_lbbuf = qbds_lb.addDataSource(tableNum(LedgerBalancesDimTrans));
qbds_lbbuf.relations( false );
qbr = qbds_lb.addRange(fieldNum(LedgerBalancesDimTrans, TransDate));
qbr = qbds_lbbuf.addRange(fieldNum(LedgerBalancesDimTrans, TransDate));
if (LedgerDistribByAlg.OffsetAccountNum)
    qbr = qbds_lb.addRange(fieldNum(LedgerBalancesDimTrans, AccountNum));
    qbr = qbds_lbbuf.addRange(fieldNum(LedgerBalancesDimTrans, AccountNum));
if (LedgerDistribByAlg.BaseAccountNum)
switch (_dimensionNumber)
case 1:
    if (ledgerDistribByAlg.DimLedgerDistribByAlg[1])
        qbr = qbds_lb.addRange(fieldName2Id(tableNum(LedgerBalancesDimTrans), "dimension[1]"));
            qbr.value(ledgerDistribByAlg.DimLedgerDistribByAlg[1]);
        qbr = qbds_lbbuf.addRange(fieldName2Id(tableNum(LedgerBalancesDimTrans), "dimension[1]"));
    break;
case 2:
    if (ledgerDistribByAlg.DimLedgerDistribByAlg[2])
        qbr = qbds_lb.addRange(fieldName2Id(tableNum(LedgerBalancesDimTrans), "dimension[2]"));
            qbr.value(ledgerDistribByAlg.DimLedgerDistribByAlg[2]);
        qbr = qbds_lbbuf.addRange(fieldName2Id(tableNum(LedgerBalancesDimTrans), "dimension[2]"));
    break;
case 5:
    if (ledgerDistribByAlg.DimLedgerDistribByAlg[3])
        qbr = qbds_lb.addRange(fieldName2Id(tableNum(LedgerBalancesDimTrans), "dimension[5]"));
            qbr.value(ledgerDistribByAlg.DimLedgerDistribByAlg[3]);
        qbr = qbds_lbbuf.addRange(fieldName2Id(tableNum(LedgerBalancesDimTrans), "dimension[5]"));
    break;
ds1 = strfmt("%1.%2", qbds_lb.name(), fieldName);
ds2 = strfmt("%1.%2", qbds_lbbuf.name(), fieldName);
queryExression = strfmt("((NOT(%2 = %1)) AND ((%2 = %1) OR (NOT(%1 = ''))))", ds1, ds2 );
qbr = qbds_lbbuf.addRange(fieldId);
// qR.reset();
while (qR.next())
    lb = qR.getNo(1);
    // Something to do
Вот полученый запрос:
SELECT * FROM LedgerBalancesDimTrans
GROUP BY LedgerBalancesDimTrans.Dimension[5] ASC
WHERE ((TransDate<=30.11.2005)) AND
((AccountNum = 25.0200) OR (AccountNum = 20.0100))
NOTEXISTS JOIN *
((AccountNum = 25.0200) OR (AccountNum = 20.0100)) AND
((((NOT(LedgerBalancesDimTrans_1_1.dimension[5] = LedgerBalancesDimTrans_1.dimension[5])) AND
	 ((LedgerBalancesDimTrans_1_1.dimension[5] = LedgerBalancesDimTrans_1.dimension[5]) OR
						 (NOT(LedgerBalancesDimTrans_1.dimension[5] = ''))))))
И при этом не работает. получаю сообщения а-ля Ошибка расширенного диапазона запроса: Ожидается правая круглая скобка рядом с 0.
Попробовал практически все варинаты... так и не работает... Как это Аксапта парсит такие запросы.... или это вообще сделать не реально? (тогда нужно действовать напрямую)
Если убрать строки
- все работает... т.е. ошибки нет, но и запрос отрабатывает не корректно.
Последний раз редактировалось rkrivov; 15.11.2005 в 12:01.
Старый 15.11.2005, 12:08   #18
Я чего-то не пойму - вам же AndyD написал, что оно не будет работать с Dimension с index > 1
возможно попробуйте вместо попыток создания query убрать то условие, которое глючит, делать while (qr.next())
//и здесь проверять ваше условие через if(dimension[5] != '34') так далее
Это дольше понятно работать будет - но зато будет.
Старый 15.11.2005, 12:33   #19
rkrivov is offline
rkrivov
Аватар для rkrivov
31 / 10 (1) +
Сообщение от kashperuk
если я уберу строки
ds1 = strfmt([color=red]"%1.%2"[/color], qbds_lb.name(), fieldName);
ds2 = strfmt([color=red]"%1.%2"[/color], qbds_lbbuf.name(), fieldName);
queryExression = strfmt([color=red]"((NOT(%2 = %1)) AND ((%2 = %1) OR (NOT(%1 = ''))))"[/color], ds1, ds2 );
то все будет работать... и не смотря на Dimension с Index > 1
К тому же с Index = 1 тоже не работает... я уже писал об этом...
Последний раз редактировалось rkrivov; 15.11.2005 в 12:38.
Старый 15.11.2005, 12:44   #20
oblin is offline
oblin
Вместо
Попробуйте
queryExression = strfmt('((NOT(%2 = %1)) AND ((%2 = %1) OR (NOT(%1 = ""))))', ds1, ds2 );
Часто помогает.
query, программно, фильтр, запрос (query)
Вопрос по Query с агрегатной функцией Jarad DAX: Программирование 11 31.10.2006 21:10
Вопрос про Query 6apcyk DAX: Программирование 5 16.11.2005 19:08
Вопрос по query и join tischenko DAX: Программирование 2 20.07.2005 13:05
Вопрос по запросу (query) Александр_1975 DAX: Программирование 2 23.01.2004 17:35
Вопрос знатокам QBE и Query в AXAPTA Maxim Gorbunov DAX: Программирование 6 27.12.2002 13:19
Часовой пояс GMT +3, время: 15:17.
